NO ICP WHEN COLD
Old Sep 18, 2013 | 09:59 AM
joeyd61's Avatar
joeyd61
NO ICP WHEN COLD
here is a new one, long story short, My terminator twins spun on the sprocket that turns it. Temporally installed a SRP1.1. Now when the truck is cold (up to 165f) the truck will not move, ICP stays @appx 600psi even a full throttle, everything is working as suppose to. Dumping fuel,Throttle position, just no ICP...after it gets warm all appears to be well. Not tuning,Jody has been working very hard on this..
Old Sep 18, 2013 | 02:08 PM
Tugly's Avatar
Tugly
If the IPR stays low (below 11%), then it's very likely tuning. It could also be some sensor lying to the truck... I had my map line loose once and the truck wouldn't power up (with my tuning). What's your IPR?
Old Sep 20, 2013 | 08:48 AM
joeyd61's Avatar
joeyd61
Rich,
IPR would go to as high as 44% with no increase in the ICP..
Problem has been resolved,after running the cylinder contribution test and 2,4,6 and 8 failing,I found the harness on the dr side unplugged. The weird thing is after the motor warmed up it would run smooth,
Old Sep 20, 2013 | 10:29 AM
Tugly's Avatar
Tugly
Originally Posted by joeyd61
Rich,
If you're running "smooth" with a whole side unplugged, I suspect my definition of smooth strays a bit from yours.
Old Sep 20, 2013 | 11:49 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
^^^^ That was funny!^^^^
Old Sep 20, 2013 | 01:09 PM
joeyd61's Avatar
joeyd61
Honestly, once warm it would smooth right out..I swear, no skips,missing or bucking.. ..
Old Sep 20, 2013 | 01:13 PM
ToMang07's Avatar
ToMang07
Were the twins wired for dual IPRs?
Old Sep 20, 2013 | 01:29 PM
joeyd61's Avatar
joeyd61
No.single IPR.Spoke to Joey about duals and he advised it is a waste of time..
IceboxFX
16
Mar 18, 2008 07:27 PM
ha305
Mar 10, 2008 05:43 PM
surfagoody
Dec 16, 2007 10:26 AM
true blue
Nov 22, 2006 06:26 PM
scouterspokane
Oct 15, 2005 05:25 PM
