I just installed a new EBPV sensor. This morning when I drove the truck I had a major decrease in power and a hissing sound coming from the exhaust. I would have to floor it to get the truck to move out. Did I screw up by installing the EBPV sensor? Do I really need to have the EBPV working at all? My goal was to clear up any codes I had in the system. The code is gone but now the truck runs like crap until I drive it for 30 minutes.
Just unplug the EBPV under the turbo. Unless you live where it is really cold, you don't need the EBPV. I have had mine gutted for years with no problems. It just takes a little longer for the engine to warm up and heat the cab.
Is it stuck shut? plowhand is right, if it eventually works right, just unplug it. Mine was stuck at one point. I pulled the plug and left it that way. I don't notice much difference in warm up time.
It has not been working since I bought the truck so there is no telling how long it has been non-operational. It is possible it needs to be used some before it performs the way it should.
Is it possible that the line leading to the EBPV sensor is restricted forcing a higher exhaust pressure before opening the EBPV? I blew air through the line when I replaced the sensor but it did not flow as fast as I thought it should. I did not think it would matter. I am thinking it might now.
How cold do you figure is really cold? I live in ma, and winters are around 20-30 on average with the possibility of some time in the teens, and possibly some time around 0. Do you think I would be ok disconnecting mine? I hate the sound it makes when you have a stright-piped exhaust, everyons stares and has a "WTF Mate?" look on their face. I don't mind a cold cab, just don't want to hurt the truck.
Thanks
Robb
If you notice any difference at all it will be that it takes a couple of minutes longer for the heater to get warm, but I doubt you'll ever miss it.
