Electric door lock actuators
Old Sep 17, 2013 | 01:06 AM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Hello all,
I just recently purchased a 1990 F350 crew cab with power door locks. The problem is only one of the door locks actually works. The passenger side front. The other three doors not only do not work, but seem to be frozen. I cannot lock or unlock them manually. Not even with the key in the case of the driver side door. I can turn it to the unlock position, but not lock. So, I checked Autozone, Pep Boys, and O' Reilly's for the actuators, and got the shock of my life. The front actuator can be had for either $43 (O'Reillys) or $70 (Autozone) however, the rear actuators are $309 each at O' Reilly's and $312 each at Autozone. Pep Boys does not sell any of them so they are no use to me at all.
Is there any way to rebuild these as I really do not want to spend $600+ for 2 actuators. I also don't want to keep my truck unlocked all the time. I did buy a Viper alarm so at least I would know if someone opens the doors, but I would also like to be able to lock them. I guess I could check the junkyards, but I don't know the chances of finding a crew cab there, or better yet, a crew cab that hasn't had the actuators taken out already.
Any help would be appreciated.
Jim
Old Sep 17, 2013 | 02:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E7TZ-3526594-A .. Rear Door Power Door Lock Actuator - Right/Left is the same / 1987/97 F350 Crew Cabs / Obsolete
Last MSRP: $346.67 / Dealer net cost: $208.00.
HOLLYWOOD AUTO PARTS (Motorcraft jobber) in Pomona CA has 19 = 909-869-7877.
Give Hollywood a call, ask what their "low buck" price is. Obsolete, so if they return them to FoMoCo, the most they'll get is the net cost.
Otherwise you may be SOL, as AFAIK, these actuators cannot be rebuilt. I used to buy from Hollywood when I was a P/M.
Norm is the owner, Russ is their outside salesman who I've known since 1968. I've known Norm even longer, but haven't seen him in 10 years.
Old Sep 17, 2013 | 07:41 AM
jas88's Avatar
jas88
What I have done on both my F150 and my Bronco is to buy a kit like this:
http://www.ebay.com/itm/4-Door-Power-Central-Lock-Kit-w-2-Keyless-Entry-Car-Remote-Control-Conversion-/300854727514?pt=Motors_Car_Truck_Parts_Accessories&hash=item460c56d35a&vxp=mtr#ht_5011wt_1172
and then modify the bracket and linkage and wiring so that that actuator works in place of the Ford actuator. Much cheaper and so far I have not had to replace one and they've been in place for many years.
Old Sep 17, 2013 | 10:07 AM
Nighteyez's Avatar
Nighteyez
Thanks for the info ND, but I think I will try the universal kit from eBay. I would rather pay $34.77 then $418.
Jim
Old Sep 17, 2013 | 12:21 PM
Eddiec1564's Avatar
Eddiec1564
I took my power lock motor out from the door and soaked in WD40 over night, then ran it off a 7.2V rc car battery to work it in. After I cleaned it off and lubed the screw acuator with engine oil(wd40 will not last) So far both locks are working and its over a year now.
You may want to hose them down with Wd40 and see if they will free up. If they do, then lube the screw acuator with oil, that's where it binds up causing the key lock and door lock to jam up. Its a PITA to get the lock motor link removed and installed to the lock mech assy! So try that 1st.
Old Sep 18, 2013 | 12:52 AM
Nighteyez's Avatar
Nighteyez
Thanks for t he tip. Will have to try that and see if I can get it to work loose.
Jim
Tom Callan
Apr 2, 2014 02:53 PM
tomrflorida
31
Feb 15, 2014 08:49 AM
justindbell
13
Nov 5, 2010 10:33 PM
KC52Flatty
May 3, 2003 12:49 PM
