door locks
Old Jun 29, 2013 | 03:55 PM
tomrflorida's Avatar
tomrflorida
door locks
time to start thinking about the doors and there only being 1 lock. How can I add a lock to the drivers door? any other ideas to lock the truck up? I do not want to remove the door handles and go with the shaved door handles and the electric kit, but I will if I have to
Old Jun 29, 2013 | 06:42 PM
Kurt G.'s Avatar
Kurt G.
Tom you can buy locks to install, my truck had locks on both doors. I plan on buying the keyless entry for mine there like $70.
Old Jun 29, 2013 | 06:57 PM
AXracer's Avatar
AXracer
I retained the OEM outside handles, latches, key locks with remote lock/unlock/alarm.
Mid Fifty sells a second door key lock kit. Mine is a custom cab so it had two locks.
Old Jun 29, 2013 | 10:34 PM
abe's Avatar
abe
simple: Lock the drivers door from the inside by pushing the handle forward, slide across the seat and exit the passenger door, then lock the passenger door from the outside using the key...
Old Jun 30, 2013 | 12:57 AM
mustangmike6996's Avatar
mustangmike6996
Lol, sounds easy enough
Thats what i plan on doing
Old Jun 30, 2013 | 01:53 PM
AXracer's Avatar
AXracer
That's the way it was done in the day. In many places it was illegal to exit on the driver's side, since all parking was parallel to the curb, opening the driver's door into traffic often resulted in instant removal of the door!
Old Jul 1, 2013 | 08:02 AM
FP's Avatar
FP
I wanted to keep the original look of not having a key lock on the drivers side, so I installed a power door lock instead. Works really well, and no one knows it has power locks. It even locks both sides when you push the handle forward on the driver's side.
Old Dec 28, 2013 | 08:27 AM
49willard's Avatar
49willard
Power door locks
I sent am E mail to FP, however, has anyone installed power door locks on an F-1?
Old Dec 28, 2013 | 09:19 AM
ALBUQ F-1's Avatar
ALBUQ F-1
This is the only one I know of (with stock door latch hardware): https://www.ford-trucks.com/forums/1...r-locks-3.html
Mid-fifties have a lot more options than BonusBuilts.
Old Dec 28, 2013 | 12:02 PM
drptop70ss's Avatar
drptop70ss
OK I may have learned something today! <p>The locks are controlled by the inside door handle? Both doors on my other F1 will not open and I assume they are locked, windows are down, but I never got around to checking to see if the latches were stuck or locked. Which way do you move the door handle from the inside to unlock the door? Does this work on the passenger side if it is locked and there is no key?
Old Dec 28, 2013 | 12:47 PM
52 Merc's Avatar
52 Merc
The key lock is a separate mechanism from the inside handle lock. If you lock the door with one, you can't unlock it with the other, and vice-versa. But the door should still open from the inside even if the key lock is activated. It only locks the handle from turning, and has nothing to do with the latch itself. The inside handle will turn one way to lock and the other way to open from it's center resting place. Give it a try and see what happens.
Old Dec 29, 2013 | 11:09 AM
49willard's Avatar
49willard
Ross,
I am visiting family out of state and had not seen your post. Thanks for the link. I had thought about the 2 different actions on the original F-1 door handles. Tom's solution in that link looks like a good solution. I will have to look at duplicating his design. I was at the point of getting the pieces to end up with keyless remotes. It is about the last item (I think) that I had not worked out on my build. I am primarily in the working to get the remaining sheet metal in final color mode.
Old Dec 29, 2013 | 01:15 PM
Gicknordon's Avatar
Gicknordon
What my plan is to get a drivers side key lock is to rob the parts off of my 5 star deluxe cab doors i have since my regular doors are in better shape than the 5 stars.
Old Dec 29, 2013 | 02:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Bill, after looking at all the door latch pics I have, I'm thinking the way to do it would be to use solenoids to operate the blocking peg that the key cylinder normally moves. Obviously you'd have to have a door latch on the DS that has the locking parts for the key cylinder, but you wouldn't have to drill your door for a cylinder.
Old Dec 30, 2013 | 06:26 AM
49willard's Avatar
49willard
Ross,
Thanks for your thoughts, I got home last night and will pull out door latches to take a look at what I can do. We had snow again last night and I need to get the tractor out to plow this AM. The doors are just in decent prime at this point so it is a good time to take a look. I do not have a drivers side lock type of latch so I would need to go on the hunt for one.
