Okay, next question. I have a crew cab, and on the drive side the two doors don't unlock or lock with the keyless entry. Now it sounds like the door lock actuator. Yet, does anyone know why it would happen just to those two doors on one side? And the other two are just fine? Anyone else have the same problem? Thanks!
Sounds like the actuators went out on that side first. Do they not work when you push the unlock/lock buttone inside the truck either? Here's a link to help:
from experience...i tried the rebuilding threads...i used aluminum foil, steel and then a penny. all worked, but each only lasted about a month. i had all 4 of mine go out together...dont know why. i ordered 4 new actuators from here AM Autoparts - Search Results for door lock actuators
and they have been working great ever since. its a real pain to keep taking out the actuator to fix the resistor...thats why for 85 bucks...it wasnt worth messing with...good luck
you are right...same for front and rear...different for left to right. if you search door lock fix...you will find a great write up. i cant located right now...good luck. its kind of a pain, until you do the first one. i think it took me 1 hr to do the first then about 15 mins each after.
