Steering HELP!!!
Old Jul 2, 2013 | 08:09 AM
bshott26's Avatar
bshott26
Steering HELP!!!
Purchased a 2008 F150 4.6L XLT, its got about 73,000km's on it.
Recently my steering has become very hard to turn left and right. While traveling at high and low speeds.
I checked the obvious, belt is fine, power steering fluid levels is good, its not leaking (no squealing sound)
Sometimes its hard to steer and then it goes away, but it's been getting worse and worse.
Please help! Thanks.
Old Jul 2, 2013 | 12:05 PM
xjcamaro89's Avatar
xjcamaro89
Intermediate steering shaft. A shaft that goes from the firewall to the steering box with a tiny universal joint that each end. The universals start to seize up causeing hard turning. I just did mine in my 07 and had to do it in my 04. You can pull it off and soak the universals in like pb blaster or wd 40 to loosen them up and get a little more time out of them or dish out 200-300 for a new one. I just got a new one.
They are easy to change. Just one clamp bolt that attach it to the shaft coming through the fire wall and one that attaches it to the steering box.
Old Jul 13, 2013 | 05:56 PM
ToMang07's Avatar
ToMang07
Just wondering if the OP ever figured this out... My brother is having the same issue on his 04.
0351mike
1978 - 1996 Big Bronco
Dec 3, 2017 04:47 PM
chrispinator
Jul 17, 2010 03:38 PM
rob8210
Aug 2, 2008 06:27 PM
ech0sh4y
40
Mar 17, 2008 07:45 PM
Peach
Jul 14, 2004 09:05 PM
