Steering box
Old Aug 1, 2008 | 07:29 AM
rob8210's Avatar
rob8210
Steering box
Does anyone know how to adjust the steering box on a 1979 f250 4x4? Thanks
Old Aug 1, 2008 | 02:25 PM
bucks77ford's Avatar
bucks77ford
What's going on with your steering? If it's sloppy, it may just be the steering shaft U-joints are bad and need a new shaft.
Old Aug 2, 2008 | 06:54 AM
rob8210's Avatar
rob8210
No its not too sloppy it just has some play in the steering that seems to come and go. I've had the front end checked out by a good mechanic and everythings seems tight, i just am not sure where this play is coming from. Once in a while it will oversteer and then will be hard to bring back. Strangely , after I have had it jacked up it won't act up for quite a while. Any ideas?
Old Aug 2, 2008 | 12:33 PM
4x4 Bart's Avatar
4x4 Bart
You can turn the adjustment screw on top of the box (loosen and hold the locking nut while you turn the adjustment screw) while you periodically check the play in the steering wheel.
Roll your window down, stand outside your door and move your steering wheel from side to side while watching your tire move back and forth.
I think you need about one inch of play before the tire begins to move.
Don't take all the play out or it will not drive right.
If your can't get the play to one inch, then your steering box or something else may be worn.
Old Aug 2, 2008 | 06:27 PM
ford390gashog's Avatar
ford390gashog
Don't adjust it too much. The recirculating ***** in the box will jam. If the box has dead spots or hard spots the box is about toast. Cardone remans these boxes and they are only 158.00 with lifetime warranty.
