Stableloads
Jun 29, 2013 | 06:17 AM
Stableloads
Guys,
I got a set of these to put on and test.
So I have them on now. They work by engaging the overloads before you add your payload or before hooking up to tow.
Basically they stiffen up the suspension so that you don't have a lot of sag or bouncing down the road.
There was no drilling or anything.
Jun 29, 2013 | 06:19 AM
And here they are mounted. You get one for the front of the wheel and one for behind it. (2 per side).
Jun 29, 2013 | 08:24 AM
Is that pin with the keeper there so you can remove them when not in use.
Denny
Jun 29, 2013 | 08:46 AM
the pin is there so you can engage or disengage them. They cannot be removed without removing the mounting bolt in the center of the leaf spring.
Last pic shows the position they are in when not in use.
Jun 29, 2013 | 10:10 AM
I see says the blind man
Denny
Jun 29, 2013 | 10:15 AM
I painted them (except the pin) and covered them in fluid film thinking that will help.
Jul 1, 2013 | 10:57 AM
How much do they retail for ?
Jul 1, 2013 | 11:11 AM
Jul 1, 2013 | 11:25 AM
Senix,
I've been looking at these and wondering if they will do much when hauling. Let us know what the difference is when towing, including bumper height before and after.
Thx.
Jul 1, 2013 | 12:00 PM
Yeah, I mean't to do a measurement of that yesterday with the 5er hooked up but didn't. I will do so.
Sep 23, 2013 | 10:04 PM
senix did these make it onto the new truck?
Sep 24, 2013 | 05:06 AM
Quote:
Originally Posted by
GHeTTo JOe
No they didn't. If I recall they were designed for the dually so I left them. Spoke to the new owner of the truck last night.
He will be towing a Montana with it. He will be using them.
Sep 24, 2013 | 10:55 AM
I also was able to be a tester for this product. I had minor problem with fitment on my dually (the instructions showed two very different pictures on the install) but figured it out and they're on. My towing loads vary from 5000-14000. I can feel a stiffer ride when unloaded and it feels more stable when hooked to the dump trailer. Testing is still ongoing.....
HAFROD
Feb 24, 2017 03:31 PM
Schickel
Nov 24, 2013 05:20 PM
oscarxyz
20
Nov 21, 2005 01:07 PM
Steve78
Jun 21, 2005 10:32 PM
77lowrider
Jul 7, 2003 08:59 PM
