remove leaf spring pins. how do you do it?
Old Nov 22, 2013 | 02:34 PM
Schickel's Avatar
Schickel
Im trying to remove the pin that goes through my leaf spring and I am having a heck of a time. So how did you guys do it? Any ideas are welcome
Old Nov 22, 2013 | 02:44 PM
Sooper Camper's Avatar
Sooper Camper
grab a big c-clamp, clamp the springs together so they don't fall apart.
vice grips on the "pin" side and wrench on the other. if its really rusted, might have to cut it off, or it'll break once you start torquing it.
new grade 8 bolt, proper length, grind down the head so it fits and you've got a new center pin.
Old Nov 22, 2013 | 03:13 PM
fordman75's Avatar
fordman75
I use a C-clamp on each side of the spring pin. Can't be too careful.
And in my area you'll never break them loose. So I usually just carefully cut it off ( on the nut side ) with a cut off wheel.
Old Nov 22, 2013 | 05:50 PM
jim collins's Avatar
jim collins
You can buy new pins that are a little extra long and you cut off what you don't need . I got mine at NAPA , our local parts store . Take one of the old ones in to get the right size .Yeah , use the C-clamps and it's a pretty easy job .____JIM
Old Nov 22, 2013 | 11:40 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
A big work bench mounted vice works great, if the spring is off the truck. Be careful they sometimes have a little pressure on them.
Old Nov 23, 2013 | 12:32 AM
Schickel's Avatar
Schickel
Got on done today just one more to go even with the tips sure was a pain! Didn't have to break out the torch though so that's a plus :-)
Old Nov 23, 2013 | 12:48 AM
77&79F250's Avatar
77&79F250
Are you doing a front or rear add-a leaf, repair work or adding leafs for a lift?
Don't forget the spring pack wrap clamp. And after you drive it for a bit (25 to 50 miles) do a re-torque on your u bolts, things tend to settle after a few miles and loosen up.
Old Nov 23, 2013 | 07:13 AM
Schickel's Avatar
Schickel
Im adding helper springs to the front packs so I can put weights on the front for pulls. And ironically the spring although only 5/8" thick gave me what would appear to be around a 2" lift. Not gonna complain about that!
Old Nov 24, 2013 | 10:55 AM
Sooper Camper
it'll settle a little bit. if you want your leaves to work better, disassemble the whole pack, clean all the rust and grime out of there and slap a fresh coat of glossy paint on there. works wonders for softening them up too, since internal sliding friction plays a huge part in how a leaf spring rides.
Old Nov 24, 2013 | 05:20 PM
Schickel's Avatar
Schickel
Actually for me the stiffer the springs the better. I plan to put around a thousand pounds of weight on the front weight bar so we need a nice stout front end
Bulldog187th
Apr 14, 2007 07:49 PM
oscarxyz
20
Nov 21, 2005 01:07 PM
Grumpy Gramps
Sep 1, 2004 12:11 PM
77lowrider
Jul 7, 2003 08:59 PM
64customcabman
Jun 4, 2002 08:01 PM
