2003 7.3L P1316 Code Nothing Works
Old Jun 30, 2013 | 06:13 PM
  #31
F350-6's Avatar
F350-6
Originally Posted by Sharonl12
OK Guys finally got the readings on the 9 Pin on the valve cover.
Going from the front to the rear
#1 nothing
#2 nothing
#3 3.5
#4 2.9
#5 .6
#6 3.6
#7 3.6
#8 nothing
#9 nothing
First I'm curious. How did you take the reading on #5? Place both pins on the same spot, or do you have the black pin somewhere else?
Second, if one lead was on #5 and you got those readings from the other lead, then I'd suggest you clear the codes (disconnect the batteries for a while if necessary, unplug the connector at the 2nd (counting the front injector as 1) injector, and start the truck up again. See if the miss isn't much better from only running on 7 cylinders as opposed to 4.
If there is a very noticeable improvement (it will still have a miss and the CEL will be on), then you've found a bad solenoid. If there's no change, move on to something else.
Old Jun 30, 2013 | 06:44 PM
  #32
Sharonl12's Avatar
Sharonl12
WOW Hope you close to your house. I did place the Black lead on the center pin and test the other 8 pins with the red wire. I had the multi meter set on Ohms 200. was not sure where to set it at as there are 5 ohm choices.
I was not sure about testing the 5th (center) pin. I did have both leads on it. Also I did test it with the batteries connected would that change it?
Old Jun 30, 2013 | 07:20 PM
  #33
F350-6's Avatar
F350-6
I always check it with the batteries connected, no problem there.
Time to pull a valve cover and unplug an injector.
Old Jun 30, 2013 | 09:16 PM
  #34
BrandonT71's Avatar
BrandonT71
I'm in Carlisle PA at the fairgrounds Off i81 exit 52
Do we have in members in that area? I would not want to be trying to pull VC's if I were stranded away from home without all the tools I needed, and being that the OP had stated in the first post about not being too good with a wrench, it sure would be nice to get some onsite assistance. Not to mention pulling the passenger side VC is "challenging" even on a good day.
Old Jun 30, 2013 | 09:51 PM
  #35
tappit01's Avatar
tappit01
this guy is the closest member to you with A/E, "99F-350CrewCab"
Old Jul 1, 2013 | 07:06 AM
  #36
Sharonl12's Avatar
Sharonl12
If someone is near and could that would be awesome. I never play the girl card but I gotta tell you this is kicking my butt. I have found muscles I didn't know existed and they are not happy. I don't have the tools. Going to AZ this morning and getting a swivel socket and a couple of extensions. If anyone is near and can help me out that would really rock. You guys have been great walking me through all this.
Old Jul 1, 2013 | 01:51 PM
  #37
BrandonT71's Avatar
BrandonT71
I'm really hoping we can get you some help, being on the West Coast, there's not much I can do but send good vibes and moral support.
Old Jul 1, 2013 | 03:13 PM
  #38
Sharonl12's Avatar
Sharonl12
Had a fairy arrive this morning who sent a cash offering took it to a repair shop. Still awaiting final but they called and said the black wire going to the center was was crushed under the valve cover. Still waiting to see if they find anything else.
Spectramac
Jul 26, 2011 06:59 PM
katula
Oct 8, 2010 01:31 PM
Islander1
Mar 29, 2008 12:06 AM
pullpin
May 20, 2007 04:03 PM
mudinford
Jul 27, 2004 09:01 PM
