Injector Buzz Test popped these codes.....
Old Jul 15, 2004 | 10:43 AM
mudinford's Avatar
mudinford
Preformed an injector Buzz test and these codes popped up:
P 1276 (Injector 6 High to low side open)
P 1278 (Injector 8 High to Low Side open)
P 1293 (Bank #1 Right side; high side open)
Does any have any suggestion what i need to tackle? We just replaced the #6 injector....and the truck misses bad when running....seems to be 2 cyl's....matches the test.
Truck is the following:
1999 F-350...one of the first off the lot!
Thanks in advance....
Dan
Old Jul 15, 2004 | 04:33 PM
International Tech's Avatar
International Tech
worst case scenario R+R both injectors or IDM fault . I would look at the connections at the valve cover and underneath it. Maybe the clips came off the injectors or the harness is pinched or broken somewhere.
Old Jul 15, 2004 | 06:08 PM
mudinford's Avatar
mudinford
I just replaced the #6 injector (First thing we did about a month ago when we had time to look at it!!!)...and R&Red the Cover Gasket and harness. Still missing like a mug. I did get an IDM code every so offten...but not all the time. I got the prementioned codes about 80% of the time when testing. Might have had something to do with low batt voltage. Got em topped off now. Seems to have a stumble when cranking too........slow, slow, slow, slow, slow, slow, slow, fast. if that makes since.
Old Jul 15, 2004 | 09:18 PM
Kwikkordead's Avatar
Kwikkordead
An open circuit is no connection. I would check the continuity at the wiring harness's. Somebody else back me up on this, but isn't it true that the wiring harness's inside the valve cover fail a lot?
Old Jul 16, 2004 | 04:00 AM
slc10844's Avatar
slc10844
Do you have much blowby? Sounds like you may have a bad piston.
Old Jul 16, 2004 | 11:59 AM
mudinford's Avatar
mudinford
Did a compression test....had compression. BUT i am not sure what i needs to start. It was well over 100 PSI. We did change the valve cover gasket and harness to the right side of the motor....did not change anything. Still missing. BUT, forgot to mention this, when the buzz test is preformed, the 6&8 injectors buzz LOTS quieter. I dont know...my end up with the dealer....i tried!
Dan
Old Jul 17, 2004 | 12:04 AM
Kwikkordead
100 psi would be only barely acceptable for a gas engine. I work on VW and Audi for a living and thier diesels have 22 to 1 compression and won't even start at anything below 375 psi if the engine is cold and the glow plugs are all working. A good VW diesel will be about 430 psi. The Powerstroke is a little lower compression but you still need to see a lot more than 100 psi. More like 300+ I would think. I think you need a whole new engine.
Old Jul 27, 2004 | 12:06 PM
mudinford's Avatar
mudinford
okok....here is a new finding we discovered last night....when we finaly had time to tinker with the truck. We pulled the fuel filter and found Texas Tea in it! It was full wtih motor oil. Injector seal leaking into the fuel? Is there a return line into the fuel filter houseing? Thanks!
Old Jul 27, 2004 | 09:01 PM
Kwikkordead
You're not going to get anywhere with low compression!!!
cutlass
13
Mar 11, 2024 11:59 AM
chris86924
Feb 4, 2017 09:28 PM
pcarr4
Dec 14, 2015 09:41 PM
bcaughhorn
44
Dec 12, 2015 10:30 AM
mototrig
Sep 8, 2015 06:48 AM
