integrated brake controller dislike replace
Old May 25, 2013 | 10:16 AM
old five string's Avatar
old five string
i have found after many years for towwing with a tekonsha brake controller and now haveing a integrated controller i do not like the new controller it alway feel like my trailer brake are not working so can i get a different switch more powerful or can i unhook the integrated switch and wire in a tekonsha
Old May 26, 2013 | 09:52 AM
Tom's Avatar
Tom
I'm sure it's possible to disable your IBC and wire in a Prodigy, but you wouldn't be doing yourself any favors. I've towed with both, and I understand what you're saying about how you can feel the brakes come on sooner with the Prodigy.
But the problem with aftermarket controllers is that they are trying to make an educated guess as to what your braking intentions are, whereas the factory integrated brake controller knows because it's directly measuring your brake pressure. I've had a couple of scary moments with both Prodigies that I've had where I've tried a panic stop and the Prodigy misunderstood. The end result was the truck's wheels locking up, the trailer wasn't braking nearly enough, and bad things almost happened.
That will never happen with the IBC, as it will ramp up to 100% stopping power before the truck bakes lock every single time. It's a much more reliable and safe system even if you can't feel it as well.
Old May 26, 2013 | 10:05 AM
senix's Avatar
senix
Usually when someone indicates that the trailer is not braking like they would like it...then the trailer brakes need adjusted or not all of them are working.
Not saying that is the case here.
The IBC integration with the truck and trailer it is just so smooth.
Old May 27, 2013 | 03:24 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Also the TBC will "pulse" the RV brakes in tandem with the truck's anti-lock brakes. That is probably why you don't think they are working correctly.....- along with the possible need to manually adjust the RV brakes.
Old May 27, 2013 | 05:41 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I think what you are felling is the difference between a proportional controller and one that relies on the truck braking to activate the trailer brakes. When I went form a Tekonsha to my Brakesmart (works like the IBC) I didn't feel like it was working either because it works off of the master cylinder pressure to activate the trailer brakes not the deceleration caused by the truck brakes. Give it a chance and you may like the smooth way it works.
Denny
Old May 27, 2013 | 11:55 PM
TexasRebel's Avatar
TexasRebel
it works...
it works so well you don't know it's working.
Old May 28, 2013 | 07:24 PM
RV_Tech's Avatar
RV_Tech
Odd man out on this one. I one of each in my two trucks and can not tell the difference. I love my aftermarket Hayes G2 in terms of stopping and the built-in diagnostics are miles ahead of the built-in.
To each his own.
Steve
Old May 28, 2013 | 07:33 PM
2006lariat's Avatar
2006lariat
You don't have electric over hydraulic brakes on your trailer do you?
My cousin just bought a goose neck equipment trailer, and ended up installing a different brake box, because the built in one wouldn't work it.
(I am not sure if the GM version is the same setup as the Ford, but his truck is a 2010 Dmax.)
The brakes work fine with the after market box.
CrossCut
2009 - 2014 F150
Nov 20, 2019 07:14 AM
Sark
6.7L Power Stroke Diesel
May 9, 2010 04:20 AM
RÖENTGEEP
All Things Towing
Jul 28, 2008 02:44 PM
jomac11
All Things Towing
19
Oct 31, 2007 12:55 PM
f350-fan-tum
All Things Towing
Nov 7, 2005 09:28 PM
