Brake Controller - Tekonsha Voyager
Old Oct 26, 2005 | 11:26 PM
f350-fan-tum's Avatar
f350-fan-tum
Question Brake Controller - Tekonsha Voyager
I just got an '04 F350 with the PSD. It had mounted in it already a Tekonsha Voyager brake controller. I have seen some positive posts on the Tekonsha Prodigy, but I have a couple questions. I am planning on getting a trailer or 5'th wheel in the 28 ft range (up to 9 - 10000 pounds).
Has anyone had experience with the Voyager?? (was it good/bad/???)
Not being familiar with newer controller design (had experience with one taking sensing from brake hydraulic line), I read that it is "inertia activated".
Does this mean at standstill, the brake controller applies no output to the trailer brakes?
On a downhill, if the brakes are applied and there is no reduction in speed, does this also mean there will be no output to the trailer brakes??
Any comments appreciated. Thanks.
Larry
Old Oct 27, 2005 | 12:03 AM
001-F DORF's Avatar
001-F DORF
I've got one in my truck and it works just fine with both of my trailers. You're correct in the inertia type of controller, but it only works when the brakelight circuit is active. You can adjust the pendulum to correct for off level mounting and the sensitivity. It can get quite harsh if too sensitive. No output sitting still is correct. If you need brakes when sitting use the manual slider. Going down hill it can be adjusted so that just resting your foot on the brake pedal enough to active the lights applies the trailer brakes.
You can get a copy of the owner manual from the tekonsha website.
Compared to the Pilot that I used with my old 3 axle trailer the Voyager is not bad. The Pilot is rate based and the longer you activate the brakes the stronger it gets, until you can't get to the stoplight. However letting up on the brake pedal totally releases the trailer brakes and so you have to get on them again to keep from running the stoplight that you didn't think you would even get to a second ago.
The Brakesmart is the best but good luck buy one of those.
Dorf
Old Oct 27, 2005 | 01:12 AM
bajaron's Avatar
bajaron
Thumbs up
Larry
I tow a 30ft 5th wheel. I first used a Tekonsha Voyager and towed from New York to So cal with it. I call it my white nuckel trip. I chaged to a prodigy and it is like night and day. The prodigy is 10 times better than the Voyager. There are also other controllers that some like better but the Prodigy will serve you well
Now have 2005 f350 with built in brake conrtroller even b etter
Ron w.
Old Oct 27, 2005 | 07:24 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I own one of them and its sitting on the shelf where its belongs not on my truck, I love my Brakesmart but they aren't available at this time so go with a Prodigy, and put the other one on the shelf.
Denny
Old Oct 27, 2005 | 09:44 AM
EPNCSU2006's Avatar
EPNCSU2006
I've never had any trouble with the Voyager. It has worked well for all the trailers I have pulled and all the vehicles I have pulled them with.
Old Oct 27, 2005 | 08:24 PM
f350-fan-tum
Wow - thanks for the great responses - but what a range of success!! Obviously not unanimous (but that's why I asked). I wonder if the difference is in the setting or ??
Thanks again
Larry
Old Oct 27, 2005 | 09:28 PM
001-F DORF's Avatar
001-F DORF
Larry,
A lot of it has to do with the condition and adjustment of the trailer brakes, and not the controller and might explain the differences in opinions. Also, some trailers just have crappy brakes to begin with.
I hated my controller until I replaced the brakes on my camper this summer, now the controller works great.
Dorf
Old Nov 7, 2005 | 09:28 PM
Delawhere?'s Avatar
Delawhere?
Larry
Larry, when you get your new 5th if it comes with electric/hydraulic disc brakes the Voyager will work with that setup as well as standard drum electric brakes. It is a good choice for a controller, but if you have just electric drum brakes the Prodigy is an excellent controller, so if you ever need to change controllers in the future give it a try, but remember it doesn't work on elec/hyrdaulic brakes systems.
SkySkiJason
17
Jun 12, 2017 07:22 PM
Medic 66
All Things Towing
26
Oct 30, 2016 07:28 PM
jaywalkin
All Things Towing
Nov 7, 2011 03:27 AM
79fordf250pickup
All Things Towing
21
Mar 9, 2011 09:30 PM
GeneStoner
All Things Towing
May 5, 2003 06:39 PM
