Offroad & 4x4
Shift on fly quit
Old Apr 5, 2013 | 09:59 AM
  #31
tjustice's Avatar
tjustice
Replaced all the fuses with new ones, still no work....Guessing broke wire some where...Any body know the part number for the wiring harness?
Old Apr 5, 2013 | 09:28 PM
  #32
wyckedcombo17's Avatar
wyckedcombo17
Did you verify that the ground for the module is OK?
Also, do you have any ABS codes?
Old Apr 6, 2013 | 10:08 AM
  #33
tjustice's Avatar
tjustice
Ground is good, NO codes what so ever... Picked up a VSS yesterday evening but haven't got it in yet.
Old Apr 6, 2013 | 11:50 PM
  #34
wyckedcombo17
Did you actually load the ground down?
Old Apr 7, 2013 | 05:39 PM
  #35
tjustice's Avatar
tjustice
Put in today still no luck with cruise. ....Ground====Truck was on switch was in many positions if thats what you mean by loading
Old Apr 7, 2013 | 10:19 PM
  #36
wyckedcombo17
You need to actually test the ground. Disconnect the harness from the 4x4 module, then take a jumper lead, hook it to B+ and then to one side of a sealed beam. Take your other jumper, hook it to the other side of the test lead and then ONLY to the the black wire in the harness you just disconnected.
Does the sealed beam light up, or is it dim?
Old Apr 9, 2013 | 04:48 AM
  #37
tjustice's Avatar
tjustice
I'm on it today, will post up after while.....
Old Apr 9, 2013 | 04:48 PM
  #38
77mud's Avatar
77mud
ITS BEEN EXACTLY 12 HOUR'S... WHATS THE VERDICT?
Old Apr 9, 2013 | 07:34 PM
  #39
tjustice's Avatar
tjustice
Sorry, got called in to work....maybe i will get to stay off tomorrow and can get it.
Old Apr 10, 2013 | 11:06 AM
  #40
77mud's Avatar
77mud
I hate it when that happens.
Old Jun 2, 2013 | 03:37 PM
  #41
tjustice's Avatar
tjustice
BTW, it was the motor....put a new on it she works just fine.......
tjustice
Mar 30, 2013 06:05 PM
oct7brian
May 2, 2009 11:27 PM
Kep4
Car/truck Buying Advice
Mar 3, 2005 08:10 PM
bigfordman70
1978 - 1996 Big Bronco
Sep 17, 2001 09:19 AM
tamarack69
Nov 12, 2000 12:41 AM
