Shift on the Fly not working
Old Mar 30, 2013 | 04:33 PM
tjustice's Avatar
tjustice
Been a good while since had to ask for help "ya" but the shift on the fly is not shifting. Checked all fuses#31 and #33 inside and the 30amp fuse under the hood #3 I think is it.... This is on 05 F-350. Anybody got a idea?
Old Mar 30, 2013 | 05:05 PM
Per4mance's Avatar
Per4mance
Sounds like you got a vacuum leak some where. Does the doors on the heater change from the floor to defrost ?
Old Mar 30, 2013 | 05:12 PM
tjustice's Avatar
tjustice
Vents working fine, manually locked hubs and nothing, has been working fine, got in some mud today and nothing....
Old Mar 30, 2013 | 05:17 PM
Per4mance's Avatar
Per4mance
Oh, you didn't say that ,ck the wires to the trnsfer case ck for corrosion
Old Mar 30, 2013 | 05:21 PM
tjustice's Avatar
tjustice
Sorry, wasn't even sure was really in right forum. I will check wires and get back with an answer.
Old Mar 30, 2013 | 05:27 PM
tjustice's Avatar
tjustice
Wires checked and are clean....Still no work
Old Mar 30, 2013 | 06:05 PM
tjustice's Avatar
tjustice
Checked the motor, yellow and orange wires no power to them. Checked the switch, getting power to it, when Ohm the switch out #1 & #4 pins on the switch ohm, turn the switch to 4h and 4L but can not get #2 & #3 pins to OHM out, but I believe that #3 was the hot coming in to the switch? I suck at electrical
tjustice
Offroad & 4x4
40
Jun 2, 2013 03:37 PM
TobiasR.
Dec 4, 2011 04:08 PM
Firefighter 1406
Dec 4, 2010 07:03 AM
Kep4
Car/truck Buying Advice
Mar 3, 2005 08:10 PM
bigfordman70
1978 - 1996 Big Bronco
Sep 17, 2001 09:19 AM
