Help IDing Extra part in 13-56 Tcase
I know this will sound odd, but what did the oil pump look like in there before you rebuilt it? When I rebuilt mine, I found a similar roller in the bottom of the case. It fit in a hole in the main shaft under the pump. Hopefully this drawing works:
http://www.alltransparts.com/wp-cont...ads/1356_a.jpg
Part #127 (there are 2) that go through the main shaft and are pressed out by a spring ride under the pump. If the retainer tab (#132) holding the pum gets torn off (as it allways does when the pump takes a crap), it will rotate the pump and those little dowel pins pop out.
lexluthr69
02-06-2018 06:52 PM
oldwillys
08-07-2007 04:56 AM
donehojo
03-11-2006 09:29 AM
Sweetred95ta
10-31-2005 06:36 PM
