1978 - 1996 Big Bronco
ELECTRONIC SHIFT
Old Aug 20, 2001 | 08:09 PM
bigfordman70's Avatar
bigfordman70
ELECTRONIC SHIFT
Old Sep 16, 2001 | 03:03 PM
BOYT's Avatar
BOYT
ELECTRONIC SHIFT
I HAVE 13-56 4X4 SHIFT PROBLEMS WILL NOT DO ANYTHING 88 302EFI CAN ANY BODY HELP P.S GOT POWER GOOD FUSE AND SWITCH1
Old Sep 17, 2001 | 09:19 AM
beratte's Avatar
beratte
ELECTRONIC SHIFT
Do you have power at the transfer case? If so, does your front driveshaft turn when you shift into 4wd? If the shaft turns then it's your hubs. Good luck, Ben
