Big time cold start issues
Old Mar 28, 2013 | 08:06 PM
  #106
Lethalthreat7.3's Avatar
Lethalthreat7.3
Yep oil is cheap compared to the to your headache? Glad you got it running. Good oil is so critical on the heui systems.
Old Mar 28, 2013 | 11:12 PM
  #107
Tugly's Avatar
Tugly
Oh please post something better sounding than that. It sounded like about 3 injectors trying to pop out of their holes in that vid.
Old Mar 28, 2013 | 11:20 PM
  #108
Bonanza35's Avatar
Bonanza35
I hope it starts in the morning, still sounds like the cyclinders are just not getting hot. At least that is better then injector problems, which would be hard to believe.
Old Mar 29, 2013 | 05:02 AM
  #109
Tugly's Avatar
Tugly
Your guy replace the GPs and it sounds like that? Until I hear another vid with it running better, I say that sounds like issues. The next time it's running, pop the oil cap and put it upside-down on top of the oil-filler tube - it should hover (not pop).
Old Mar 29, 2013 | 07:36 AM
  #110
HKusp's Avatar
HKusp
Yeah, I am hoping it was just the fact that the injectors were purging air, and bad oil and thats why it was so rough. Before I sent it down to have the GP's and the UVCH's done, that is how it started if I didn't have it plugged in. That is why I am catiously optimistic about having all the issues worked out. I am hoping that it will fire up this morning without being plugged in and run nice and smooth. I am waiting until 9 am to try it. I want to give the neighbors a break just in case they are sleeping in this am. I will check back as soon as I have something to report and I will video it, of course.
Old Mar 29, 2013 | 08:31 AM
  #111
white Buffalo's Avatar
white Buffalo
Jason, here is a crappy cell phone video I quickly shot this morning of starting my F-250 that has been sitting for a few days. When I took the video it was 30 degrees outside. I did not allow the glow plugs to energize, I just tried to start it cold. Very similar to your video posted above. Chugged & jerked along with plenty of white smoke, almost started but just wouldn't hold idle. The 2nd time I started it I waited until the "wait to start" lamp went out.
Just like Tugly (Rich) said, your video sounds like the glow plug system is just not getting the cylinders warm.
Sorry for the lousy video, especially the audio portion - just figured I would throw this at you for a comparison.
http://s304.photobucket.com/user/Whi...4e43d.mp4.html
<a href="http://s304.photobucket.com/user/White_Buffalo/media/coldstart_zps5a44e43d.mp4.html" target="_blank"><img src="http://i304.photobucket.com/albums/nn169/White_Buffalo/th_coldstart_zps5a44e43d.jpg" border="0" alt="cols start - no glow plugs video coldstart_zps5a44e43d.mp4"></a>
Old Mar 29, 2013 | 08:35 AM
  #112
HKusp's Avatar
HKusp
Long video, not good, but listen to it.
Old Mar 29, 2013 | 08:45 AM
  #113
HKusp's Avatar
HKusp
Still definitely has issues.
As I am posting this, it is sitting here on high idle and has been running for maybe 10 minutes and is purring like it should, but as you could see in the previous video and a little in this one, it's still got a major issue somewhere.
Old Mar 29, 2013 | 08:48 AM
  #114
HKusp's Avatar
HKusp
No blow by at all.
Old Mar 29, 2013 | 09:09 AM
  #115
Tugly's Avatar
Tugly
Disregard... just heard the next vid. I was freaking out with that rattle of half your injectors not firing.
PMing
Old Mar 29, 2013 | 10:40 AM
  #116
tdpower's Avatar
tdpower
How many miles on your truck/injectors? I was hoping the oil change would fix your problem. Starting to look like worn injector poppets. You can measure them with a feller gauge to see if they are in spec. Here is some info from swamps diesel: http://www.swampsdiesel.com/files/7....Diagnostic.pdf
Old Mar 29, 2013 | 02:34 PM
  #117
Bonanza35's Avatar
Bonanza35
I'd go threw the hope electrical system for GP and relay. I know you said you tested it, but I would pull the valve covers and do it again. Check your pins closly. Even with your light on to show GP working you mitt not be getting enough voltage for the full time needed to warm the cyclinders. When this checks out, if it dose, then I'd say injectors, not before. You could send your IDM to swamps also to have them check that out and do the up grade. Most guys that have them really like them. Following, sorry your having so many problems.
Chet
Old Mar 29, 2013 | 04:28 PM
  #118
white Buffalo
Jason,
Here is the link to Woodnthings' website on the glow plug system.
https://sites.google.com/site/woodnt...ow-plug-system
How long did it run rough? at 40 degrees it shouldn't take long at all to clean up and idle smooth.
Old Mar 30, 2013 | 10:48 AM
  #119
HKusp's Avatar
HKusp
I ran it all day yesterday and after it smoothed out it ran like it should have. Turned it off several times and it was fine. It is 57 degrees out today and I plugged it in for an hour this am and went out to start it and it started perfectly and is running, as I type this, smooth as silk. I was supposed to go to my fathers today and pull the drivers side valve cover and see what is going on underneath there, but my brother is having a plumbing emergency at his house and we are into day 2 with a mini excavator and hand tools looking for a collapsed terra cotta pipe in his front yard, so it will have to wait. I will post back when I get into and probably have pictures and maybe another video
P.S. - Tugly, I checked the GP LED last night, and it is hooked up correctly.
Old Mar 30, 2013 | 11:11 AM
  #120
CampSpringsJohn's Avatar
CampSpringsJohn
Last week the GPR went out on my 97. What I like to do to notice if the GP's are working is leave the door open when I turn the ignition on and see if the dome light dims a couple seconds after turning the key.
