E4OD Operation
Old Jun 25, 2014 | 05:34 AM
  #121
danlee's Avatar
danlee
Originally Posted by danlee
Yes, I just did that picture. I had a 20 x 30" poster made.
BTW, The '53 has an E4OD with a Baumann Controller. The controller that I'm working on is for my '83 F100. It's just a beater with a good running 302 and a rebuilt E4OD. I only use it to haul large stuff or heavy loads. It's also a good truck to experiment with, as I don't use it often.
Old Jun 25, 2014 | 10:58 PM
  #122
LonnieCole's Avatar
LonnieCole
That is a gorgeous truck.. Very nice..
Old Jun 26, 2014 | 09:58 AM
  #123
danlee's Avatar
danlee
The trans controller is behaving much better, but I'm having trouble with the crimps on the connector pins. The pre-crimped pins will be here today, but I might not have time to install a new connector with the new pins until Sunday.
Old Jun 26, 2014 | 09:59 AM
  #124
danlee's Avatar
danlee
Thank You!
Old Jun 30, 2014 | 07:40 PM
  #125
danlee's Avatar
danlee
The cable problems are fixed, and the RPM calculation seems to be OK, but I'm still having a problem. The controller will shift a couple of times then stop. I have some Print statements in the code, but my terminal doesn't get any output after the controller stops shifting.
I think that there is some exception that causes the processor to get lost. I'll try to get help from the processor board people.
Old Jul 2, 2014 | 04:15 PM
  #126
LonnieCole's Avatar
LonnieCole
Does it run any better without the print statements? Sometimes prints can disrupt interrupt handling. It might be easier to set up a couple of LEDs on output pins and send a code out on those for debugging (I'm assuming you don't have an oscilloscope to look at signals?). You might want to make sure that any of the input pins that have alternate functions that are useable as interrupts are set up as general I/O and not the interrupt alternate function.
Just a thought.
Sounds like you're getting pretty close though. Nice job.
Lonnie
Old Jul 2, 2014 | 04:23 PM
  #127
LonnieCole's Avatar
LonnieCole
BTW, is the Coridium board you're using the one with the LPC1756 part or the LPC1751?
Old Jul 2, 2014 | 06:48 PM
  #128
danlee's Avatar
danlee
Just a thought.
Lonnie
I can try turning off all of the print statements. I have a scope, but I need a very long cord to power it while I drive down the road.
I might try to simplify the code, and use just the necessary statements to debug it. I probably won't get much done until after the holiday.
Old Jul 2, 2014 | 06:52 PM
  #129
danlee's Avatar
danlee
I used the SuperPro with the LPC1756, because it has a built-in DAC. It should be overkill for this application, but it simplified my hardware.
Old Jul 3, 2014 | 08:53 AM
  #130
danlee's Avatar
danlee
I tried a simplified version of the code. It shifted through all 4 gears. I need to install some LEDs to verify that, however. I have the LED drivers already implemented in the code, and hardware.
I have the EPC disconnected, so some of the shifts are hard. It's possible that the original code was OK, but the 'Print' statements were messing it up.
I'll get the LEDs first, then try the old code, then reconnect the EPC. I disconnect the EPC because I was afraid that the EPC ground current was the cause of my problem.
Old Jul 3, 2014 | 08:59 AM
  #131
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I have one word for you: Inverter.
I spent most of 19 years driving with an oscillograph in the car or truck powered by an inverter. The prices have come down a lot recently.
Old Jul 3, 2014 | 10:10 AM
  #132
danlee's Avatar
danlee
Mark,
What are the problems associated with not driving the EPC. I do not have my EPC driver connected now, and other than some hard shifts, it seems to be fine.
Old Jul 3, 2014 | 10:32 AM
  #133
Mark Kovalsky
Hard shifts and a bit more torque required to turn the pump, which will make a very small hit on fuel economy. That's about it.
Old Jul 5, 2014 | 09:28 PM
  #134
LonnieCole's Avatar
LonnieCole
Danlee
Are you particular about what color LEDs you want? I have a bunch and I could send you some if you'd like.
Mark is right. If your scope is a relatively newer one (mine is a small Tektronix DSO probably 10 years old or so) I think it would run with no problem on an inverter.
Let me know about the LEDs.
Lonnie
Old Jul 6, 2014 | 05:00 AM
  #135
danlee's Avatar
danlee
Danlee
Lonnie
I picked up some LEDs at Radio Shack. I wired them using a small perf board that I had left over from another project. I used a spare ULN2003 driver and some 150 Ohm resistors.
I drove the truck, and it shifted through all 4 gears. All of the LEDs turned on at the proper time, except 3rd gear. I think that I have a wiring or software error. The 3rd gear and the Torque Converter lockup LEDs are swapped. I don't have TC lockup code running now.
Other than that it worked fine, but it didn't want to down shift to 1st, after driving a distance. It seems that some value must be accumulating, and preventing downshifts to 1st gear.
My scope is a 30+ YO Hewlett Packard unit that I purchased used for a few bucks. I think that it would take a large inverter to power it. It is portable, but it weighs quite a bit.
I'll solve the LED problem, and look into the downshift problem.
