E4OD Operation
Old Jun 18, 2014 | 09:24 AM
  #106
Scndsin's Avatar
Scndsin
My bad. Thought you had the type that was mounted in the top of the pumpkin & reads off the ring gear.
Will try & get out to the shop this AM & check whats actually on my wire shelf.
Old Jun 18, 2014 | 10:15 AM
  #107
Scndsin's Avatar
Scndsin
Sorry, turned out to be 18#. Must have loaned out my 16# roll.
Old Jun 18, 2014 | 01:45 PM
  #108
danlee's Avatar
danlee
David,
!8 AWG is OK. I just don't want 24 or 26 AWG, because my solder connections will break too easily.
Is that a Foil Shield? The wire on Ebay has a Braided shield. That will be easier to work with.
I have a $20.00 Ebay promotional credit, that expires the end of the month. I don't need anything else right now, so I might as well use the credit.
Thanks for your offer.
Old Jun 20, 2014 | 01:53 AM
  #109
speedwrench72's Avatar
speedwrench72
Mark my E4OD in my 91 E350, 7.3 (newly rebuilt) is locking and unlocking tc between 35-45 mph with light throttle, only when warm (15 mins of driving) any ideas?? nice tech...
Old Jun 20, 2014 | 04:38 AM
  #110
danlee's Avatar
danlee
The 14 AWG Twisted Pair cable should be here by Monday 6/23. 14 AWG is a little heavier than I need, but it should be easy to splice to my connectors.
Old Jun 21, 2014 | 03:22 PM
  #111
danlee's Avatar
danlee
The twisted pair wire came today. Sat. 6/21/14. I spliced the transmission connector onto the new cable. It's MIL Spec cable. It's really tough stuff.
I couldn't upload a picture.
I promised someone that I would go fishing tomorrow, but as soon as I get home, I'll fish the cable through the firewall and connect it to the trans. If I don't get it all wired tomorrow, I'll finish and test it on Monday.
Old Jun 22, 2014 | 12:28 PM
  #112
LonnieCole's Avatar
LonnieCole
Sorry for the hit and run.. Wife's new knee and anniversary duties called..
Danlee, I looked at the SuperPro board you're using (assuming I found the right one). Pretty nice board. Lots of capability. Quick question.. about the differential receiver you're using.. are you using on-board I/O or are you using a dedicated differential receiver part? I'm assuming you're using the truck wiring harness signals for the VSS? since you're getting spurious interrupts without the truck running (should be a pretty quiet electrical environment). The experiment with a dedicated signal is good. A couple of things I'd be concerned about is the interaction of the VSS with the existing control system. I don't recall what year your truck is but if it has a VSS it must be ECU controlled? If so, depending on exactly how you have it connected currently, the ECU "MAY" be trying to actively control the VSS... i.e. I'm not sure if the current ECU is passive. There's a good chance that assuming that the ECU at the very least is supplying power to the VSS, the power it is providing may have switching noise on it. Do you have an oscilloscope to look at the signal coming from the VSS? I would offer to check on my truck but it's too early a model to have a VSS.
So depending on exactly how you have the VSS wired into your board, there may be a couple of more things you could do to alleviate the noise issue.
Lonnie
Old Jun 22, 2014 | 01:32 PM
  #113
LonnieCole's Avatar
LonnieCole
Oh, one other thing.. Did you ever determine if the EPC can be PWM / Voltage controlled or did you pursue that any more?
Old Jun 22, 2014 | 02:52 PM
  #114
danlee's Avatar
danlee
I never determined that it could or couldn't be PWM, since my controller does Current control with the onboard DAC, an OpAmp, and a transistor.
Old Jun 22, 2014 | 02:59 PM
  #115
danlee's Avatar
danlee
Lonnie
My truck is carb'ed and does not have an ECU. The VSS is only used for the Trans Control. I am using a dedicated Differential Receiver, but the VSS wiring is only a factory harness for part of the run. I am going to bypass all of the existing VSS wiring with the new cable.
Old Jun 24, 2014 | 07:03 PM
  #116
danlee's Avatar
danlee
I installed the new VSS cable, and also extended the other wires in the truck cab, so I can get better routing for a permanent install of the trans controller.
I had some problems with the crimps on some of the connector pins, and I got Solenoid 1, and Solenoid 2 swapped trying to fix the pins.
I had some spurious interrupts, but one of the VSS cable pins was not seated in the connector. I'll try to get all these problems fixed tomorrow. I ordered some crimped pins with pigtail wires. They should be here Saturday. If I don't have it all straightened out by then, I'll start over with a new connector & the premade crimped pins.
Old Jun 24, 2014 | 08:18 PM
  #117
LonnieCole's Avatar
LonnieCole
Would you mind sharing which differential receiver part you're using?
Lonnie
Old Jun 24, 2014 | 08:19 PM
  #118
LonnieCole's Avatar
LonnieCole
BTW, is that picture in your sig. your truck?
Old Jun 24, 2014 | 09:00 PM
  #119
danlee's Avatar
danlee
Yes, I just did that picture. I had a 20 x 30" poster made.
Old Jun 24, 2014 | 09:02 PM
  #120
danlee's Avatar
danlee
Lonnie
It's a Maxim MAX9924. It's available from Mouser. I know someone else who is using it for a speed sensor, without any problems.
