E4OD Operation
Old Jul 28, 2014 | 06:58 PM
  #151
danlee's Avatar
danlee
Remember this is a prototype.
Old Aug 1, 2014 | 08:03 PM
  #152
danlee's Avatar
danlee
Torque Converter Lockup works. I got the up and downshift points fairly good, but I may tinker with them later. The EPC control works, but when I connect it, the MLPS signal gets noisy , and my Range selection jumps around. I am certain that this is due to the EPC ground current getting mixed with the MLPS return current. I have to examine the ground wiring in my controller to find this problem.
I have finished the PC board layout. As soon as I get the ground problem fixed, and get the controller working correctly with the EPC, I can order some PC boards.
Also, I have to mount the controller and route the cable.
Old Aug 7, 2014 | 09:46 AM
  #153
danlee's Avatar
danlee
I rerouted the grounds, but that didn't help. I put a bypass capacitor across the EPC current control transistor to ground, and that fixed the problem. Now the unit shifts smoothly & properly.
I am going to order some PC boards. I would like to sell some for about $50.00 each to defray my cost.
Old Sep 2, 2014 | 01:18 PM
  #154
danlee's Avatar
danlee
Update on my controller.
I have used the truck with the new controller installed for a little while. The shifts are smooth at light throttle, but gets harsh with a little more throttle. I need to adjust the EPC table to fix that.
The only other problem is when I am cruising at 45 MPH in 3rd or 4th gear, and mash the gas pedal, the trans will downshift all the way to 1st, and cause the motor to over-rev. That will require an adjustment of the 2nd gear downshift table.
Aside from those things, it works OK.
There are a couple of things that it doesn't do.
One is that there is no OD cancel switch at this time.
The other is there is no Coast Clutch selection, so you can't do engine braking.
There is no way for someone, other than me, to adjust the shift tables.
I have the PC board on order, and have many of the components. I will build a new unit with the PC board, and look at adding some features. However, I have to send the PC board to get some Surface Mount parts installed. That will delay any more development.
Old Sep 2, 2014 | 01:28 PM
  #155
techningeer's Avatar
techningeer
It's awesome that you've come this far danlee.
I could personally live with no O/D cancel, but not having the coast clutch is pretty big deal for me, and may be for some other people. Just a FYI input. I love my engine braking an without it, the Ford auto wouldn't be any better than the Dodge 4spd auto which SUCKS to say the least. Also, in case you didn't know the coast clutch is used as a fallback clutch in case of tranny failure. So, my Q, do you think you can get coast clutch working?
Old Sep 2, 2014 | 04:06 PM
  #156
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I didn't know that. Can you explain?
The only clutch that it could replace is the OD one way clutch.
Old Sep 2, 2014 | 06:38 PM
  #157
danlee's Avatar
danlee
I'll look into getting the Coast Clutch working when I build the next unit. One thing that I forgot to mention, Torque Converter Lockup only works in 4th gear. I could add it to 3rd easily.
Old Sep 4, 2014 | 10:10 PM
  #158
techningeer
From this webpage:
http://www.becontrols.com/ourfaqs/e4...2.htm#01190332
All the power that comes into the transmission in first through third gears comes in through the OD one-way clutch. There is also a coast clutch that will perform the same function as the OD one-way, but it is only intended to provide engine braking. Since it is only meant for engine braking it is a very small clutch pack and does not perform the work of moving the vehicle forward well, that is why you get the sluggishness. The coast clutch is only applied when OD is cancelled, or manual first or second is selected. This is why your transmission works under these conditions. In OD normal operation is that the coast clutch is off and the OD one-way is overrunning, therefore, OD works normally.
I can confirm the thing about manually selecting a gear and it works but not when in Drive, I have seen it on several E4ODs
And BTW not trying to argue so correct me if I'm wrong but this is how I've always understood it. IIRC my ATSG manual says much the same thing...
Old Sep 5, 2014 | 09:21 AM
  #159
Mark Kovalsky
And that's what I said, too. It can't replace any friction clutches, only the OD one way clutch. So we are agreeing, just not understanding each other.
Old Sep 5, 2014 | 01:55 PM
  #160
techningeer
Oh I see what you're saying.
Sorry for the confusion.
Old Sep 10, 2014 | 04:43 AM
  #161
danlee's Avatar
danlee
This is the PC board. I have to send these out to get the Surface Mount ICs placed & soldered. Then I will load them with the other components.
The place that I am going to send the boards is in Ontario Canada, and they charge me $8.00 for each component. There are three Surface Mount Components on each board, and the cost is $24.00/board plus shipping. I have been looking for a local and/or cheaper place to get this done.
I'm going to start with 2 units.
Old Sep 24, 2014 | 08:16 PM
  #162
danlee's Avatar
danlee
Controller Circuit Board with Surface Mount ICs installed.
This is the controller circuit board with the surface mount ICs installed. Now I need to load it up with the rest of the components.
Old Sep 24, 2014 | 08:23 PM
  #163
FORDF250HDXLT's Avatar
FORDF250HDXLT
yikes.can't have that.
Old Sep 24, 2014 | 08:36 PM
  #164
danlee's Avatar
danlee
I have already fixed that problem, and also the harsh shift at part throttle. All that it took was a simply adjustment of the Shift Tables, and the EPC table.
Old Sep 24, 2014 | 08:38 PM
  #165
FORDF250HDXLT
nice job man.
