The CB thread
Old Jul 14, 2013 | 08:53 PM
  #91
raystankewitz's Avatar
raystankewitz
Clarifications
Originally Posted by Hutch17
I was planning on grounding out the headache rack
when I said Ground Plane, I did not mean electrically grounding the antenna to something. It has more to do with antenna theory.
A little bit of reading http://en.wikipedia.org/wiki/Ground_plane
Large, flat metal surfaces are best. Hood, roof, you get it. Tubular items such as headache racks and lumber racks are poor ground planes.
Hope that clarifies my comments.
73 de Ray - AG6TH
Old Jul 22, 2013 | 01:57 PM
  #92
351Cleveland C4's Avatar
351Cleveland C4
My SWRs keep changing themselves!!!!!!!!!!!
Ive got my cobra 29ltd classic hooked up to my 4ft mag mount stuck in the middle of my roof. I run the coax through the roof over the headliner. the extra gets pushed up in the headliner.
I had my swrs almost as good as it gets, highest reading under 1.5 on all channels. I was very pleased. now I haven't touched a dang thing since then and now theyre through the roof! lowest reading is 2.5 on channel 40...
I tried pulling the coax out of the roof and putting the antenna all over the truck just to see if I could find a spot that would create some lower readings, I couldn't...
why would this happen all of a sudden?
Old Jul 22, 2013 | 09:39 PM
  #93
raystankewitz
What?!?
Well, sounds like the mount or coax might be going away.
Place it on a surface, get a baseline SWR reading, then move the coax around just a bit. See if the SWR changes.
Mag mounts and coax exposed to the elements usually don't last long.
Old Jul 24, 2013 | 06:23 PM
  #94
351Cleveland C4
is it possible that the surroundings can change swr readings? I don't know much on tuning, just that high is bad and low is good and a bit more.
it occurred to me that ive never had the truck where it is right now, (underneath our tower and next to our steel shed)... obviously that changes signal reflection and what not but would it put the swrs up like this?
Old Jul 24, 2013 | 11:28 PM
  #95
raystankewitz
Huh?
You should be out in the open, nothing around for fifty feet all around. Stay clear of high tension lines, parking lot light poles, towers and large steel sheds.
When you check SWR, make sure the doors are closed and nobody is standing outside when you do your checks.
Hope this helps.
73 de Ray AG6TH
Old Jul 26, 2013 | 06:55 PM
  #96
351Cleveland C4
yes that gives me a better idea of what I need to do, guess I have to wait till I can drive her out into the open to see whats going on...
Old Aug 7, 2013 | 09:07 PM
  #97
351Cleveland C4
whats a good antenna to get if I wanted to buy a new one? without empting my pocket...
I want a mag mount with a spring....
Old Sep 6, 2013 | 03:26 PM
  #98
351Cleveland C4
K40 V Lil Wil v road pro
having trouble deciding on what antenna I should buy. ive split between these 3
A) the k40
K40 35" Magnet Mount Stainless Steel CB Antenna, 300 Watts - K40
B) the lil wil
Wilson "Little Wil" Magnet Mount CB Antenna Kit, Boxed - Wilson
C) road pro
RoadPro - 36" Magnet Mount CB Antenna Kit #RP-707
I like the k40, made in USA!
Wilson is of course the big wig,
the road pro unit is a little cheaper, and has a spring.
all 3 are in the "Road Pro Family"
I like springs for driving under trees, but is it a quality antenna?
id rather have something that will last and perform the best and can brag about than just say, "oh its just some cheap POS I bought"
OPINIONS AND EXPIREINCES ARE WANTED! good bad or otherwise... which one?
Old Sep 17, 2013 | 04:24 PM
  #99
farmerobrown's Avatar
farmerobrown
I have ran 6-8 Lil Wil's and they will talk great and last a long time with a radio by itself or a small box in the 75-125 watt range.
The coax Will Not take getting the door shut on it so would be coming through the gromets. The magnet holds great will put with 'some' limbs and stuff ok.
I haven't ran the others but have herd the K40's were very good at one time.
Best of luck, FB
Old Sep 17, 2013 | 05:31 PM
  #100
raystankewitz
My 0.02 USD worth . . .
I'll suggest you go with the K40. Good antenna according to the reviews.
The Lil Will isn't bad, either, although it isn't tolerant of big branches.
Last edited by raystankewitz; Sep 17, 2013 at 05:33 PM. Reason: hit post instead of review.
Old Feb 6, 2014 | 01:05 AM
  #101
351Cleveland C4
Bump. This is a good thread. Let's not let it get pushed back into the depths of the FTE files.
Old Feb 7, 2014 | 02:01 PM
  #102
Redneckfordf2502002's Avatar
Redneckfordf2502002
Currently still working on the set ups in a few of our trucks.
One is a Cobra 18 series mounted under the ash tray of my 88 F150. Still have to hook it up. Going to get a stock antenna and mount it on the drivers side so it looks stock.
2 is a cobra 19 or 50 series mounted under the dash of the 84 B2 of my brothers. Still need to hook up a antenna and going to do the same again.
3 is the same as the B2 has mounted under the ash tray on the 89 F350 of my other brothers. Once again doing the same set up as the 2 above. Only plan using them to communicate with my brothers while we are driving together or doing a job.
4 is a portable one that is in the 02 F250 right now but probably going to be put in the 89 F250 so my dad can communicate with us (he doesn't want a rigid one).
Trav
1976and2001_250
Aug 17, 2010 12:28 PM
jfarmer
1983 - 2012 Ranger & B-Series
Mar 15, 2007 08:45 PM
turboale
May 22, 2006 08:38 PM
Flip4ford
Kansas Chapter
Dec 10, 2005 03:20 PM
equium
13
Apr 16, 2004 08:09 PM
