John.. that's what I was thinking... especially after putting a new battery last year.. I put the 750's cause they were free..lol
Ok I have to ask did you only replace one battery?
They really should be done in pairs. This is do to the way they age.
If you have one new and one older the system will have a lower total
output and the batteries will not be carrying the load in a balanced
manner.
You need to remove the batteries and have then charged and then tested
both by electrical and hydrometer to see what you have.
No sir... I can live with the spitting and sputtering for now.. I'm just worried at the battery issue...
Well...
You could dump your oil and fill with 5W40 and verify your FICM voltages now or spend $2500 + labor later to replace all 8 injectors since they are dying a slow death with what you're doing.
Also have the starter tested.
If you have fresh batteries and a running voltage of 14 volts those items should be fine.
You're still rather vague in what the engine is doing and did not address Benny in Post #5...
Is it cranking slow and then firing or cranking over 150+ rpm and just takes a while?
Running like crap until 150 degrees sounds the most like injector stiction, but also a FICM issue.
Ford recommends 15W40 only down to 20 degrees. While not all people that use 15W40 experience stiction issues, it is more common. I would switch to 5W40 personally.
As far as the battery issue, do you have a parasitic load? Have you put an ammeter inline with the battery cables? I agree w/ Sean that you need to individually test those batteries (load test and hydrometer).
6.0 Oil Recommendations:
Some trucks with the 6.0 may exhibit hard starting, rough running and lack of power in cold temperatures, particularly on a cold start. This may be due to the oil being to thick for the operating conditions. Ford is recommending to use the following oils for the listed operating temperature.
SAE 15W-40 is the preferred oil above 30 degrees, but it is acceptable for use down to 10 degrees, and is recommended for towing down to this temperature.
SAE 10W-30 is the preferred weight between -10 to 30 degrees.
SAE 5W-30 and 5W-40 is acceptable for use below 30 degrees, and 0W-30 is acceptable below zero.
(All temperatures are in Fahrenheit.)
It cranks fine.. I can hit he remote start and it fires right up after the glow plug delay.. if the batteries are good and charged which is most of the time.. seems like if I plug it in it starts right up unless I have to cycle the glow plugs twice... if I don't plug it in that's when I have the at try issues
... I have put a fluke meter on the alt which showed 13-14..same fluke meter on the batteries and they showed about the same... I've put lucus fuel additive in also about every 2 or 3 tanks...
As far as a parasitic load
. I turn 2 way radios off at night. It has a viper remote start with security on it but don't use the security part very often...
