Valvespring Tech
Old Nov 1, 2012 | 01:09 AM
68cabby's Avatar
68cabby
Valvespring Tech
Okay guys, got the cam and lifters ordered. Waiting for them to come in on Friday...not sure if I SHOULD have gotten the springs too..or if the springs are necessary for the comp 260h cam. the head only has 45,000 miles on it, so the springs are fairly fresh. Does anyone see a problem posing that the 260h may not get the "recommended" valvesprings? Has anyone used their stock valvesprings? just a few tidbits before deciding if i should go back to order them..I'll just have to scrounge a bit.
Old Nov 1, 2012 | 06:12 AM
OverReved's Avatar
OverReved
I would go with whatever the cam manufacturer suggests. That way you are covered if there is a problem. Good luck
Old Nov 1, 2012 | 08:58 AM
AbandonedBronco's Avatar
AbandonedBronco
Definitely check with the manufacturer. They're going to know better than anyone. Most people on here are going to make educated guesses at best, and that's not what you want for your engine. Comp is really good about getting back on stuff like that in my experience.
Old Nov 1, 2012 | 09:02 AM
Harte3's Avatar
Harte3
What they said X3.
Old Nov 1, 2012 | 09:55 AM
68cabby's Avatar
68cabby
Ok..thankfully the dummys at the auto store ordered a v8 cam..so I can go back to reorder with the valvesprings..now..can anyone help me? I'm lookin for the comp 260h cam kit WITH the valvesprings..but not Tue timing stuff? I've seen it..just can't find it. Any help appreciated!
Old Nov 1, 2012 | 10:10 AM
AbandonedBronco
You could just get the kit you were going to get and add the valve springs on the side. Or, contact Comp and ask what the kit is. They'll know for sure.
Old Nov 1, 2012 | 11:35 AM
68cabby's Avatar
68cabby
Good idea
Old Nov 1, 2012 | 11:48 AM
AbandonedBronco
When I was looking at kits, it was one that just came with the cam and lifters, or one that came with everything. I don't remember seeing one in between.
Old Nov 1, 2012 | 12:36 PM
68cabby's Avatar
68cabby
Well..I suppose I can get the cam and lifters..contact comp and see their specified springs and see if they have a "spring package" that comes with the locks and keepers and such. I decided just to keep the original timing gears..so that's 60$ ill save..or else I WOULD get the whole kit.
Old Nov 1, 2012 | 07:20 PM
68cabby's Avatar
68cabby
Alright..I got the FULL kit..now..it says that retainers are not included..but did you get new retainers AB? I'm officially in no mans land as nobody around me or helping me knows as much about the 300 as I do..and this whole cam swap and valvespring change is all new to me. I'm gonna get the fitting for the pressurized air for the valvesprings as I still don't wanna take off the head.
Old Nov 2, 2012 | 08:55 AM
AbandonedBronco
I didn't get retainers, but I did hear they're the same as the 302, so you can get some of those. (May want to double check to confirm that).
But, retainers are one of the few items in the valve train that aren't really a "wear" item, so most of the time you can just reuse your old ones.
Old Nov 2, 2012 | 09:11 AM
68cabby's Avatar
68cabby
Cool beans I'm on my way!
bearster18
17
May 2, 2025 05:45 AM
HVACTOM
Mar 13, 2015 09:34 AM
fordnut2008
Aug 27, 2008 01:39 PM
oldblue31
May 21, 2005 08:13 PM
fordtruckin
Mar 7, 2002 08:38 PM
