cam installation questions!
Old Mar 6, 2002 | 04:25 PM
fordtruckin's Avatar
fordtruckin
Hey, when you put in a new cam, what else (besides the vavle springs) do you have to do? Bearings? rods? I just want to find out now so I don't get any surprises at the shop. y'all know what i'm talking about, when they give you the bill and you do this: :-staun
Old Mar 6, 2002 | 11:51 PM
karljay's Avatar
karljay
Lifters & break in lube for one. You might get tapped for springs, retainers, locks & pushrods, but the only one of those that might be needed is the springs if the cam require different springs.
Most good shops would check the condition of the push rods, springs... but some say buy new everything.
Old Mar 7, 2002 | 02:52 AM
fordtruckin
the edelbrock cam I'm looking at comes with new lifters as well as lube I believe....
Old Mar 7, 2002 | 09:39 AM
BB's Avatar
BB
Don’t forget a new timing chain and sprockets. To put everything back together you’re going to need a gasket set too.
Barry
Old Mar 7, 2002 | 04:00 PM
FE427TP's Avatar
FE427TP
Old Mar 7, 2002 | 05:49 PM
fordtruckin
ooooh yeah I forgot about the new timing! Good thinking!
Old Mar 7, 2002 | 08:38 PM
Sunny_in_hollister's Avatar
Sunny_in_hollister
Don't forget the front cover seal. Also inspect the balancer sleeve for wear. Sometimes you'll find a groove worn in it from the old seal. Felpro sells a repair sleeve for it if you find it worn. ARP sells a new cam bolt for a few bucks - cheap insurance. Check the push rods and rocker arm assemblies for wear. Push rods are cheap if you need a new set.
Reggie
