Quality universal joints????
Old 10-17-2012, 09:15 PM
Eallend7's Avatar
Eallend7
Eallend7 is offline
Need passenger side universal joint. 86' f250 6.9L 4x4 and i've looked on places like rockauto, but i read you should get the dana joints. Not sure if you can even get those, and if it's worth the brand name, or if there are other quality replacements??? advice?
Old 10-17-2012, 09:34 PM
Onus's Avatar
Onus
Onus is offline
I'm using the precision ones that a greasable for the last 5k or so. No problems. Just keep em greased.
Most recommend the non greasable spicers since they are solid all the way through. You have to track down the part number for those. You can go on dana and look them up.
http://www2.dana.com/expertforms/dek350.aspx
Go here put in your year and model.
Old 10-17-2012, 09:57 PM
Eallend7's Avatar
Eallend7
Eallend7 is offline
Sweet thanks onus. i'll shoot them an email and see where i can order at and how much we're looking at payin here. See if this fixes our little problem
Old 10-17-2012, 10:04 PM
Onus's Avatar
Onus
Onus is offline
No problem. Anytime. If you get the part numbers of there past them into google. Should find more than a few places to get them online.
Old 10-17-2012, 10:39 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
If you wheel hard and break joints, get the solid ones, if not, i would highly recommend the servicable joints, especially in the front end, theyre not exactly the most fun to replace.
Old 10-18-2012, 06:06 AM
Eallend7's Avatar
Eallend7
Eallend7 is offline
i aint takin this thang wheelin hard, shes gettin painted up and lifted up, but not mudded up. shes a cruiser(;
Thanks for the input hairy, i checked it out, they're about the same price, makes sense to have a serviceable joint, if it moves it should have a grease fittin... my opinion..
Old 10-18-2012, 08:06 AM
Onus's Avatar
Onus
Onus is offline
I totally agree you can never have enough grease fittings. Heck my tie rod boots are shot but since they have grease fitting i just keep greasing them.
Old 10-18-2012, 10:40 AM
hairyboxnoogle
Onus, might check with NAPA, im pretty sure you can get replacement boots for tie rods and such.
Old 10-18-2012, 01:06 PM
300-6 AUTO TECH's Avatar
300-6 AUTO TECH
300-6 AUTO TECH is offline
I like things to have grease zerks too, but a sealed Spicer joint will outlast them.
Old 10-18-2012, 05:30 PM
Eallend7's Avatar
Eallend7
Eallend7 is offline
it appears we have muddied the water! let the battle begin!
SEALED VS GREASABLE!
Old 10-18-2012, 05:35 PM
hairyboxnoogle
Quality sealed joint vs. quality greasable joint, the greasable wins.. goes for rod ends balljoints... anything that moves really.
Old 10-18-2012, 05:37 PM
Eallend7's Avatar
Eallend7
Eallend7 is offline
hahah. ill probably go with the greasable either way, just tryin to start a ruckus (;
Old 10-18-2012, 06:03 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
I just replaced mine a few months back with sealed Dana Spicer Long Life U-joints. I like the greaseable idea, but never remember to actually grease them. Plus these were cheaper and I'm on a real limited budget right now. I figured that sealed Spicer joints will outlast greaseable cheap joints. I agree they are a real pain in the *** to change. I thought I was going to break my harbor freight 20 ton press.
Dana 60 Front Axle Ujoint Spicer 5 806X SPL55 3X | eBay
Old 10-19-2012, 04:36 PM
Onus's Avatar
Onus
Onus is offline
I'll have to check that out.
nagetech
07-19-2017 07:01 PM
DieselCamper
18
08-03-2016 05:52 AM
Redneckmorton
09-14-2012 09:39 PM
countrysF250
1999 to 2016 Super Duty
01-12-2006 04:20 PM
Quick Reply: Quality universal joints????
