Rocker arm problem
Old Oct 19, 2012 | 11:40 AM
rLmcowboy's Avatar
rLmcowboy
Rocker arm problem
Due to not torquing a rocker arm bolt I have broke the aluminum piece that holds rocker arm down! And bent a push rod. I can get a new rod but can't find the aluminum piece and new bolt. I've read that I can use newer dryly from 7.3 but can I just replace what is needed or do I have to do all?
Old Oct 20, 2012 | 02:03 AM
RacinNdrummin's Avatar
RacinNdrummin
Aluminum piece?
Old Oct 20, 2012 | 05:27 AM
Jim Allen's Avatar
Jim Allen
That's easy to do. You have to replace the pair of rockers with the 7.3L style and replace everything as an assembly. You aren't going to find the old style rocker pivots with the bridge any longer. They aren't expensive and are readily available.
Old Oct 20, 2012 | 08:27 AM
mudguts's Avatar
mudguts
I have a rocker arm set new in the box. send me a p.m.
Thinlizzy13
Oct 11, 2015 03:47 PM
ar15man
Apr 4, 2008 10:21 AM
edo379
13
Feb 25, 2008 01:28 PM
tonpartain
19
Feb 25, 2006 07:37 AM
78 Ranger
Feb 23, 2006 10:58 PM
