Need Opinion on Aftermarket Oil Cooler
Hey Guys & Gals, My buddy wrecked his truck! What a bummer, but I get some of the leftovers...Helluvaway to get parts huh? Anyway his truck had a 6.9 n/a. He bought an oil cooler kit for it, the kind that has a radiator and a thermostat. Supposedly it has an adapter that screws on where the filter goes and fits fl-1a filters. He didn't get a chance to install it so it is still in the box. I can get it for $40.00 bucks.
I have always thought our stock oil coolers did a good job, however I do tow a 5th wheel a lot as well as some gooseneck trailers hauling cows around here in Texas. My question is...is it worth installing? Will my old truck get any benefits? The thermostat will block oil flow to the radiator at 170 degrees and allow flow at 180 degrees. That sounds like it would keep the oil to cool, that's why I am asking these questions.
Thanks for all opinions and suggestions,
BeerCan500
BeerCan500
Oil Cooler
Anyway, if I get to feeling froggy and all wrenched up I might just install it.
Stock Oil Cooler
Oh well, I'll just keep waiting to see what the other guys have to say. Maybe it will turn out to be useful for something...maybe cooling the oil right before going into turbo or something...
Transmission
Nah, I got a zf-5...I think I know where u wuz goin. I do remember some posts about a guy who drilled some holes in the pto plate on his and hooked up a cooler but I never could figure out where he got the pressure to pump the fluid through cuz I thought the zf-5 didn't have an internal pump like a 6 does.
ZF-5 Lasting Longer
You're right, the ZF-5 does not have an internal pump. You could add an electric one easily enough. I wonder if a fuel pump would have enough flow. Its also possible to use the mechanical lift pump on the engine if you've added an electric pump to the truck. Again, I'm not sure how much that would flow, but even if its a bit slow, the extra cooling would help the ZF last longer.
Might be worth searching for an answer. Heck, you could even hook up a good temp gauge too...What go you think? I think it might be a good idea and not all that difficult to accomplish.
BeerCan500
bodywerks
02-10-2014 07:56 PM
