Oil cooler fix
Old Jul 28, 2014 | 08:27 AM
polosabre's Avatar
polosabre
Oil cooler fix
I would like some feedback on moving the oil cooler on my 04 F350 6.0L diesel. I have replaced oil cooler 3 times in less than 2 years. I still have high oil temps. Coolant temps stays around 190-194, but oil temp usually 15-20 degrees higher and thats not pulling my fiver. I have spent a lot of money on my truck and plan on keeping her. Its got ARP Studs, new heads, new injectors, IPR Valve,oil cooler delete, 4" exhaust, coolant filter, Edge monitor, plus i just added another oil temp gauge just to see if i was getting good oil temp reading. When pulling my fiver coolant and oil temp can vary up to 35+ degrees. Any suggestions would be greatly appreciated.
Old Jul 28, 2014 | 08:30 AM
jswartz84's Avatar
jswartz84
Are you running an OEM oil filter?
It could be a worn out oil filter base.
Old Jul 28, 2014 | 08:42 AM
Money-Pit's Avatar
Money-Pit
What brand oil coolers have been installed?
After the 3 oil coolers were installed, did you see improvements in your oil temps (and they gradually increased over time) or did your oil temps remain high after the install?
There are kits to move the oil cooler, however it's a good idea to find out what is causing the problem in the first place.
Old Jul 28, 2014 | 09:59 AM
polosabre's Avatar
polosabre
I use OEM oil filters and coolers. The oil temps have always been higher than the normal 15* deltas. The deltas are usually 15-20 not pulling anything on interstate at 65-70 mph. I do have a Taylor Wing on it.
Old Jul 28, 2014 | 11:03 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
With 3 oil coolers and no improvement you need a new filter base since your old cooler bypass is obviously worn out.
Josh
Old Jul 28, 2014 | 06:12 PM
cheezit's Avatar
cheezit
Have you replaced the serp belt? Have you pulled the water pump and looked for cavation in the front cover?
Old Jul 28, 2014 | 08:49 PM
polosabre's Avatar
polosabre
New hoses, belt, water pump, tstat.
Old Jul 28, 2014 | 08:50 PM
cheezit's Avatar
cheezit
Ok so what did the front cover behind the pump look like?
Old Jul 28, 2014 | 10:56 PM
daddykitty's Avatar
daddykitty
Maybe you should get an oil analysis to see if your problem lies deeper than the oil cooler
Old Jul 29, 2014 | 06:41 AM
MC5C's Avatar
MC5C
My first thought was oil cooler bypass as well. What condition were the second and third oil coolers in, where they clogged or good? You have deleted the EGR cooler so why do you even care about delta's now? Delta is only relevant to a potential EGR cooler failure. In your case I would just worry if the oil temp got too high for the oil, in the 240 degree range. Or change the oil cooler bypass. There was a guy with ridiculous oil temps after a cooler change and I recall his issue was the bypass.
Brian
Old Jul 29, 2014 | 03:13 PM
Per4mance's Avatar
Per4mance
Still waiting for an answer to Cheezit post
UNTAMND
19
Apr 9, 2014 09:41 AM
blkdiesel
Aug 13, 2009 03:49 PM
ZooDad
May 29, 2009 12:58 AM
averagef250
May 3, 2004 09:38 PM
bigred78
Dec 23, 2001 11:28 AM
