Minnesota Chapter Join Chapter, Leader: fordpower88
June B.S. Thread
Old Jun 6, 2012 | 05:15 AM
  #316
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by DieselCamper01
How are you tonight Jim?
I wasn't ignoring you Jay. For some reason I couldn't get back on FTE after I posted last night. I thought the site went down so I gave up after a while
Old Jun 6, 2012 | 06:09 AM
  #317
Racer5349's Avatar
Racer5349
Originally Posted by MisterCMK
Nope.....
Feel free to break it, but don't do it until after saturday!
Old Jun 6, 2012 | 06:35 AM
  #318
Ford79's Avatar
Ford79
Good morning everyone.
Old Jun 6, 2012 | 07:17 AM
  #319
Jigger2020's Avatar
Jigger2020
Good morning everyone, hava good one.....
Old Jun 6, 2012 | 07:29 AM
  #320
fordpower88's Avatar
fordpower88
Good morning everyone! Welcome to Hump Day everybody!
Well I got the boat all fixed last night but no time to get it on the lake so that will have to wait for another night. It was a PITA but it is done.
So Dave the word on the street is you got that gap on your truck filled in but yet no pics??
Old Jun 6, 2012 | 07:35 AM
  #321
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Morning Troy, what was the issue with the boat?
Old Jun 6, 2012 | 07:54 AM
  #322
fordpower88
Well last winter I rebuilt the motor and then when I finally got a chance to test it out I backed in the water and realized I had water coming in quite fast. Turns out the shift cable bellow was tore open so I replaced that last night. Should be all good now I hope. I would like to do all the bellows just because but that will wait till this winter I think.
Old Jun 6, 2012 | 07:56 AM
  #323
Devious Delight's Avatar
Devious Delight
Originally Posted by Skill_Kills
I've had this idea for years now, but with an early 50s f100 and a 7.3
matter of fact i think i have a couple trucks i should be looking at:
1954 FORD F100
1953 ford f100 pickup
I like this idea. In fact, I think you should do it twice, since everything is so much easier the second time
Originally Posted by msmenne17
I'm not looking to add more registers. There are two 18" registers ineach of the upstairs bedrooms with one cold air return in each.
I'm looking to get the hot air out. There are no roof vents other than on the ends of the house and a broken power vent. I'm probably going to start by fixing the broken power vent. I might need to seal off the ends and open up the soffets to prevent a short circuited air flow. Ice dams are also a problem in the winter. I'm hoping that by insulating and getting the hot air out, this will help that problem as well.
If that doesn't work, I'm looking at a whole house fan as well to pull the air through the house. My parents had one in CO. It was very effective. It won't take care of humidity, but it will at least reduce the load on the air conditioner.
I did change the filter tonight. It was definitely due. Air flow is definitely increased. We'll see if it makes any difference upstairs.
Time for bed. Night all!
You don't have any roof vents on the top of your house, just the soffits?
Good Morning all.
Old Jun 6, 2012 | 08:01 AM
  #324
DieselCamper01's Avatar
DieselCamper01
I could not either so I gave up. Seems like a lot of nights FTE goes wonky about that same time.
Good Morning all.
He said there were vents on the gable ends only. Definitely help to get some roof and soffit vents.
Old Jun 6, 2012 | 08:57 AM
  #325
fordpower88
Good morning Dustin and Jay!
How is Lynn doing Jay?
Old Jun 6, 2012 | 09:00 AM
  #326
sddesigns's Avatar
sddesigns
FTE Emeritus
Yup, when one goes the others aren't too far behind!
Old Jun 6, 2012 | 09:14 AM
  #327
DieselCamper01
Hello Troy. She seems to be doing ok. It is a constant struggle to get her to not push herself too hard but I think I am succeeding a little anyway.
Old Jun 6, 2012 | 09:25 AM
  #328
msmenne17's Avatar
msmenne17
Good Morning everyone!!
It's Wednesday!! Only two days until Friday!! Can't wait.
Old Jun 6, 2012 | 09:26 AM
  #329
msmenne17's Avatar
msmenne17
Good Morning all.
There are no roof vents other than a broken power vent. There are vents on the peaks of the gables. I'm not even sure the soffits are open. The bottom side is vented, but I haven't looked to see if they are sealed above the siding or not.
Old Jun 6, 2012 | 09:32 AM
  #330
DieselCamper01
If there are not vent chutes in the attic rafters odds are things are blocked from air flowing through there Michael.
