Minnesota Chapter Join Chapter, Leader: fordpower88
June B.S. Thread
Old Jun 5, 2012 | 11:58 AM
  #271
msmenne17's Avatar
msmenne17
Anyone have any experience with attic venting? The air conditioner (about 5-10 years old) can barely keep up and their is a 10*-15* difference between the upstairs bedrooms and the main floor and another 10*-15* difference between the main floor and the basement. The air conditioning bill this summer is going to kill us unless we figure something out. Even at 80* outside, the air conditioner runs for hours just to cool the house a few degrees.
Old Jun 5, 2012 | 12:08 PM
  #272
Devious Delight's Avatar
Devious Delight
Originally Posted by DieselCamper01
Chris, any chance you have an inch/lbs torque wrench?
Yes please. I need to tighten the clutch bolts down and I only have a ft/lb wrench. You have it at work or home? I probably don't need it tonight but more like tomorrow.
Sorry I won't be around this weekend to help.
I have one Jay, I can bring it to you and give you your muffs back. It's 1/4" drive.
Old Jun 5, 2012 | 12:11 PM
  #273
MisterCMK's Avatar
MisterCMK
It is at work. I'll toss it in the pickup and drop it by for you tonight probably.
Old Jun 5, 2012 | 12:16 PM
  #274
MisterCMK's Avatar
MisterCMK
Is it central air?
Old Jun 5, 2012 | 12:18 PM
  #275
Devious Delight
Another boat for Troy...
**Retro 1975 20' Caravelle Boat***
I think I'm going to need to learn how to do boats... I'm begining to think I want one...
Old Jun 5, 2012 | 12:37 PM
  #276
DieselCamper01's Avatar
DieselCamper01
Since Chris only lives a few blocks away I will have him drop his off Dustin. No huge hurry on the ear muffs. Whenever works or your in the area.
Thanks Chris that would be great. I should be around for sure after 9 otherwise Lynn should be there.
Old Jun 5, 2012 | 01:04 PM
  #277
msmenne17's Avatar
msmenne17
Is it central air?
Yup. Central air.
Old Jun 5, 2012 | 01:17 PM
  #278
fordpower88's Avatar
fordpower88
You could have a couple things going on. The fan does not have enough power to push the cold air all the way to the top floor. You could have a plugged condenser outside or evap inside. How is the airflow coming out of the vents? I would clean them or at least look at them and check. Could be low on freon. Checking for low freon would require gauges. Inadequate insulation in the house itself. Make sure the vents to the basement are closed so you are not trying to cool that. The a/c unit itself is too small for the size of the house.
Too much of a project for what I am interested in.
Old Jun 5, 2012 | 01:31 PM
  #279
msmenne17's Avatar
msmenne17
The airflow isn't exactly stellar up there. The furnace and A/C were replaced around 5 or 10 years ago. I wouldn't be surprised if it's too small. The P/O got cheap when it came to things like this.
I don't think it's low on freon. The air coming out of the vents is COLD. It's either an airflow problem or heat buildup issue (probably both).
The insulation is probably about 50 years old, except the attic. We insulated the attic towards the end of winter. There was only 3" up above the bedrooms. Now, there is probably close to 20". The house is a story and a half with the upstairs bedrooms being built into the roof trusses. The East bedroom isn't too bad, but the west one with all of the afternoon sun is horrible.
Old Jun 5, 2012 | 01:38 PM
  #280
fordpower88
Sounds to me like airflow maybe the biggest issue if everything else is cold. I would check the coil inside the unit in your basement. That could be partially plugged causing low airflow. From there I would check with a hvac guy and see what size unit your house is suppose to have and see if that is the problem. If it is there is only one fix and that is a different a/c unit. You might also be able to get a bigger fan for the the house that spins faster and pushes more air.
Old Jun 5, 2012 | 02:02 PM
  #281
wildstang's Avatar
wildstang
VT Chapter Ldr
Weighs less than a Super Duty and is a freeway loafer. Must be talking about a Chevrolet.
64 ford galaxy wagon with a twin turbo 6 liter stuffed in it
Old Jun 5, 2012 | 02:04 PM
  #282
wildstang's Avatar
wildstang
VT Chapter Ldr
Once your camper ac is fixed you can plumb it into the house to help
Old Jun 5, 2012 | 02:06 PM
  #283
Excursion4X4's Avatar
Excursion4X4
Where did you bring the cover Dale? I know there is a place in Rogers.
Can't think of the name right off, but it is at hwy 81 and 63rd. Just South of 694.
Same place Dave took the blue truck.
Old Jun 5, 2012 | 02:08 PM
  #284
Excursion4X4
Had them do a couple of things for me so far.
Old Jun 5, 2012 | 02:10 PM
  #285
Devious Delight
was talking to the hvac guy at work. check the filter, it could be plugged or too restrictive. He was saying that he'd do the cheapest filter possible, and just change it every month, assuming you don't have alergies.
