Call All Experts On ECT vs EOT Spread
Old May 25, 2012 | 11:07 PM
  #46
jl4407's Avatar
jl4407
Is there any way to trouble shoot a failing water pump?
Old May 26, 2012 | 01:08 AM
  #47
RPM371's Avatar
RPM371
Originally Posted by BLADE35
Were ypou towing when those temps was taken??????
Its seems High Both ect and EOT so I dont think its scangauge or temp senders
watch both EOT & ECT as it warms up to temp for any big Jumps or high & Low temp changes
Could change thermostat to OEM cheap worth a shot
It also can be the case theres a coolant flow issue from Cavitated front cover and or water pump
I was pulling a 25" gooseneck flatbed with a 3K load.
Old May 26, 2012 | 06:20 AM
  #48
RPM371's Avatar
RPM371
Just checked my degas bottle and I've got fuel in the coolant.
Old May 26, 2012 | 07:17 AM
  #49
bismic's Avatar
bismic
You have a cracked head.
Old May 26, 2012 | 09:27 AM
  #50
RPM371's Avatar
RPM371
That is NOT the answer I was looking for!
Old May 26, 2012 | 10:54 AM
  #51
BPofMD's Avatar
BPofMD
Veteran: Navy
OK... you have TWO cracked heads!! (SORRY, I couldn't resist - an old Jimmy Durante joke)
Old May 26, 2012 | 03:15 PM
  #52
RPM371's Avatar
RPM371
LOL! Sadly, you are probably right knowing my luck.
Old May 26, 2012 | 03:31 PM
  #53
BLADE35's Avatar
BLADE35
Well besides it was Hot temps the Deltas look like they are within the 15* Spec or Realy Realy close considering you was towing when those numbers was taken
I am leaning towards a Bad Thermostat or Bad Front Cover and or a Water Pump Problem or maybe even junk in the radiator that needs cleaned out to let the Air flow pass threw the Radiator fins to cool properly
and with Diesel Fuel in the Coolant you have a Bad Injector Cup in the Head and the Best way to fix it is New Heads Sorrey
I have read the Injector Cups are able to be changed but its Very Hard to get them to Seal Back up so thats why folks go with New Heads
Kinda looks like Multiple Problems Here
Old May 26, 2012 | 05:07 PM
  #54
RPM371's Avatar
RPM371
I talked to my mechanic and he says cracked head(s). $2500 +/-
I tell ya some days it's hard to be a Ford guy...
Old May 26, 2012 | 05:57 PM
  #55
bismic's Avatar
bismic
It is tough sometimes - sorry for the bad news.
Old May 26, 2012 | 06:24 PM
  #56
69cj's Avatar
69cj
Look at the bright side, your still mowing the lawns from the topside.
Old May 26, 2012 | 09:54 PM
  #57
nitrogen's Avatar
nitrogen
I flushed my system using Cat cooling system flush. as to what it might or might not have cleaned out I can't say. the flush chemical was in the system for about 5-6 hours of driving to/from and around the city shopping. basically fully hot the whole time. 2 R/O water flushes afterwards it still looked like medium iced tea. the only drive since that really matches the ford test, I had straight water in but my delta went down about 4-6 degrees. perhaps the cat chemical dissolves stuff rather than knocking it loose as particles. 115,000 without a coolant filter, just switched to red ELC , still gots me a great delta (:
Old May 27, 2012 | 02:38 AM
  #58
RPM371's Avatar
RPM371
Took it over to the shop and told him to replace the head, new OEM head gaskets on both sides, ARP studs and new degas bottle. This better be the last thing to go wrong for a while because I'm running out of money.
danocross
Aug 24, 2020 07:39 PM
f350ranchand
Jul 29, 2013 10:38 PM
jl4407
Jul 5, 2012 12:23 AM
Unrealo4
Feb 28, 2011 06:50 PM
fatcowvtx
Dec 6, 2010 05:44 AM
