Call All Experts On ECT vs EOT Spread
Old May 18, 2012 | 09:24 PM
VQT's Avatar
VQT
- I know about the test on the Oil cooler with carefully do a WOT, drive 65 mph, temp. speard 15*... I think I even read it in the workshop manual. So, with that out of the way.
- Most people with good oil cooler says their truck stay around 10* spread even towing up long incline...
- Bismic/Mark, you say not to worry until the oil temp pass 220*
What do you think about the condition of my oil cooler? These data were taking on 12 May 2012 with outside temp. around 97* to 100*. These data wer not taken on level highway. There isn't any level highway in Las Vegas for long distance to really take the correct test.
ECT EOT
198* 215* HW at 75 mph on I 15 North away from Las Vegas toward Utah
190 212 HW at 75 mph
197 214 75 mph
193 211 45 to 50 mph
186 203 35 to 45 mph Toward Lake Mead, Valley of Fire
191 214 35 to 55 mph
195 221 up hill driving away from Hoover Damn toward LV
193 220 Same road as above driving toward Las Vegas
190 218 Some what level Highway before exist to my house.
Do you think to be safe, change the oil cooler now and stop thinking about it, or can I wait and do a 1,500 miles round trip this July/August?
Old May 18, 2012 | 09:26 PM
dlibson's Avatar
dlibson
Time to do it. Those splits are pretty big...
Old May 18, 2012 | 09:33 PM
Piolet's Avatar
Piolet
Great walk through of the entire process here in a playlist of 7 videos on youtube. Sounds like you do have to replace the oil cooler.
6.0lit Powerstroke Head Gasket Teaser - Intro - YouTube
Old May 18, 2012 | 09:46 PM
VQT's Avatar
VQT
Thank You Colm
Old May 18, 2012 | 09:55 PM
bismic's Avatar
bismic
VQT - do you have an EGR cooler delete?
Old May 18, 2012 | 09:56 PM
BLADE35's Avatar
BLADE35
X-2^^^^^^^^^^^^^^^^^^^^^^^^^^
I drove last summer down to Mesquite Nevada from Salt Lake Utah Truck Loaded with all my tools Saws,Compressors, bunch of Material as well. It wasnt Heavey maybe 1K total Cargo load caused more Wind Drag than anything
Ambeint was 115*
I was right at a 8-10* spread ECT vs EOT at all Times Uphill Downhill at 60mph-90mph whatever the conditions were Deltas stayed 8-10*
But keep in mind at that time my Oil Cooler was just changed and only had around 5K miles on new oil cooler. And 15K since the Oil Cooler still hangs same Deltas.
I guess what Im saying is you want to Flush cooling system good and run a coolant filter to avoid a repeat Oil Cooler Pluging. Oh FYI most shops WILL NOT flush a cooling system as thuro/repeated times as some trucks need to come clean. IMO it was worth it to me to spend extra time Flushing the coolant system clean to attempt to avoid future Failure.
Old May 18, 2012 | 10:03 PM
VQT's Avatar
VQT
Had this truck since Dec 2011, no plan on EGR delete, don't know if I should since they do smog check here in Nevada.
Old May 18, 2012 | 10:07 PM
BLADE35's Avatar
BLADE35
You also shouldnt go by say a EOT 220* like you mention
True that this temp the Oil is fine and not cooking ****
But its the Fact that your beyond a 15* ECT vs EOT Temp Spread and the Oil Cooler is plugging on the Coolant Half. So with Blocked coolant ports in the oil cooler no Coolant is getting to EGR Cooler and the reduction of flow could have a negative affect on coolant flow threw the Heads Block ect.......... I know EGR & Oil Cooler coolant flow is a Bypass so to say but whoes to say only those parts in that Loop are affected
Old May 18, 2012 | 10:09 PM
bismic's Avatar
bismic
VQT - Thats what I thought. If you go back to my statements in the thread where I mentioned 220 degrees EOT, you will see that I prefaced it with the statement "since you (the other thread starter) have an EGR delete" ........... I was trying to be clear on that point!
A big part of the problem with the oil cooler plugging is that it restricts the EGR cooler's coolant flow (and the EGR cooler has a high heat load). This adds stress to the EGR cooler and can cause it to fail.
I will never say that it is OK to ignore the 15 degree spec if you still have an EGR cooler (even if it is a BPD cooler and I am impressed with how well built they are).
You have a restricted oil cooler and it needs to be changed.
Making sure the details are communicated over the internet sometimes proves to be a challenge!
Old May 18, 2012 | 10:11 PM
bismic's Avatar
bismic
Benny - a restricted oil cooler does not mean that NO flow is getting to the EGR cooler. If that were true, then no flow would be going through the oil cooler either.
That being said, I will again emphasize that I stated 220 degrees (in the other thread) based on NO EGR cooler being present.
Old May 18, 2012 | 10:16 PM
VQT's Avatar
VQT
Benny,
I install the coolant filter already right after the first coolant flush in March. Since march, I have clean the block three times, twice with 1/2 gal restore and 1/2 gal restore plus. Back fush the oil cooler close to 3 hours. Right now it has 3.5 gallons of Delo ELC concentrate. how much more flushing are you suggesting and what type before I tear it down?
Still waiting for the water bill to come in
Thanks,
Old May 18, 2012 | 10:22 PM
VQT's Avatar
VQT
Thanks Mark,
That's why I want to make sure I understand all the issues particular to my engine set up.
Thanks again for clear that up for me.
Old May 18, 2012 | 10:49 PM
BLADE35's Avatar
BLADE35
Yes Sir Right with Ya^^^ I know exactly what your getting at just the OP might not. Just the way he posted all his temps and inquired about the EOT 220* I suspect he not quite on the same page as You
With EGR Cooler Gone the Main Ticking Time BOMB is out of the equation and a guy could push it futher
I guess I just mean it was designed with a Oil Cooler so EGR Cooler or Not we still want a Functioning Oil Cooler so same Delta rules apply to see oil cooler health Cheezit mentioned it the other day that a plugged oil cooler could affect flow in other areas
People see that EOT 220* as ok and some situations it is OK and other situations its NOT OK
like a ECT of 210* with EOT of 220* would be fine even 230* EOT is fine as long as ECT was within 15*
IMO a ECT vs EOT delta of more than 15-20* apart Overrides any other Temp Operating Value and needs repaired
Just trying to bring him upto speed
Old May 18, 2012 | 11:05 PM
BLADE35's Avatar
BLADE35
Originally Posted by VQT
Benny,
Thanks,
Great^^^^ I didnt know you have been working at it just trying to save you a down the road Headache
Iv seen Folks come here on there 4th Oil Cooler Bad Mouthing Ford and the works bad design
But come to find out the MAJOIRITY of repeat Oil Cooler failures have NEVER had the Cooling system Flushed and cleaned out good so the repairs just were not done right
Alot of the repeat oil cooler Failures have come from shops and I beleive some of these shops know dang well the cooling system needs flushed but they only install another oil cooler knowing its going to plug again down the road and you will be back for another oil cooler its Job security
Old May 18, 2012 | 11:08 PM
VQT's Avatar
VQT
Benny,
Am I good to go at this point to just prepare to do the oil cooler replacement or should I flush some more? What kind of flush?
Thanks,
