New oil cooler
Old Jul 29, 2013 | 01:47 PM
f350ranchand's Avatar
f350ranchand
New oil cooler
My eot and ect run as high as 23 degrees apart does this mean I need a new oil cooler
Old Jul 29, 2013 | 01:51 PM
mustang_309's Avatar
mustang_309
<p>What was your ECT when you recorded that delta?</p> and what were the conditions when you checked the delta?
Old Jul 29, 2013 | 02:08 PM
f350ranchand
Ect was 118 and just normal driving down the hiway at 70 mph and about 95 degrees outside
Old Jul 29, 2013 | 02:26 PM
f350ranchand
I meant eot 118 ect 93
Old Jul 29, 2013 | 03:17 PM
69cj's Avatar
69cj
eot/ect deltas are only meaningfull when the engine is totally heat saturated and up to temp. Takes app. 20 to 30 minutes at highway speeds to attain the proper temps. Ect should be in the 190 range. The temps you quoted are meaningless.
Old Jul 29, 2013 | 04:18 PM
Yahiko's Avatar
Yahiko
Get the truck up to temp and get on the freeway
drive 20 minutes then hold 65 MPH 5 minutes
read temps. Also truck should be unloaded and freeway should be flat.
Post back the EOT and ECT
One other thing is when you do get a temp spike does it come back down fast?
Sean
Old Jul 29, 2013 | 06:37 PM
f350ranchand
Eot 117.5 ect 93 normal driving down the hiway
Old Jul 29, 2013 | 06:48 PM
william_04_x's Avatar
william_04_x
If that's *C, you should look at replacing the oil cooler. (243/199*F).
Old Jul 29, 2013 | 07:19 PM
69cj's Avatar
69cj
Good catch William on the possibility that those temps are celcius.
Old Jul 29, 2013 | 07:49 PM
BLADE35's Avatar
BLADE35
Deleate this Post
Old Jul 29, 2013 | 10:38 PM
BryanStein's Avatar
BryanStein
If those temps are celcius, and after warm-up, and sing 65 unloaded......
I just replaced an oil cooler with 40 degree deltas after 30 min on the road, driving ,65 with no load on flat terrain. My delta dropped to 7 degrees.
You must have an egr delete, or lucky the egr has not blown yet.
When u do the cooler, put in a new ipr screen. Do as good coolant flush using international restore and restore plus. The run international EC-1, silicate free coolant with a coolant filter. Dump the ford coolant.
DO NOT COMPROMISE ON THE COOLANT FLUSH.
I had to replace an oil cooler after 60k miles because someone didn't flusj the coolant after an egr rupture.
wisevoss
Jan 29, 2014 04:51 PM
jl4407
Apr 3, 2012 03:29 AM
High Binder
Oct 21, 2010 08:19 PM
