Call All Experts On ECT vs EOT Spread
Old May 18, 2012 | 11:30 PM
BLADE35's Avatar
BLADE35
Originally Posted by VQT
Benny,
Am I good to go at this point to just prepare to do the oil cooler replacement or should I flush some more? What kind of flush?
Thanks,
But NOT knowing the steps taken to flush hard to say
I always removed the thermostat for the entire flush routine and when I had cleaners in it I would set to High Idel or 1100rpms and push maximum flow of cleaners threw it for 1 hour it cleaned it really good 4-6 flushes later and the water was as clean/clear going in and coming back out.
I tried to flush with thermostat in and it sucked the water never would flush clear
Sounds like you have cleaned pretty good and have been running a coolant filter for a few now thats how I did it too
Old May 18, 2012 | 11:41 PM
Roasted7's Avatar
Roasted7
I drove down the exact same roads as you VQT, in about the same heat, same time of year, pulling a trailer and I was getting 50+ degree spreads.
Mt egr cooler has been deleted and I had no trouble.
I have since replace the cooler and drove the same roads in the same heat pulling the same trailer with a 10 degree spread.
Bottom line is that if you still have that egr cooler, then you probably better get that oil cooler replaced.
You can see precisely what will cause a 50+ degree spread here. https://www.ford-trucks.com/forums/1...oler-pics.html
Old May 18, 2012 | 11:56 PM
VQT's Avatar
VQT
I think I did clean the engine block as much as I can also with the back flush of the oil cooler with your suggestion to stuff rags around the oil cooler cap to retrieve tool drop which was very good information.
Old May 19, 2012 | 12:39 AM
Fulthrotl's Avatar
Fulthrotl
Do you think to be safe, change the oil cooler now and stop thinking about it, or can I wait and do a 1,500 miles round trip this July/August?
not an expert here, just a newbie, with new parts. :-/
your numbers are worse than mine, the last 250 miles was
huntington beach to san bernadino to san diego, to huntington beach.
on a warm day.... i was running the defroster on high on the way home.
on level ground thru camp pendelton, it was sitting on 230 water and
245 oil.
it was 210/200 that morning..... 250 miles.....
july, vegas? do you have AAA premium with 200 miles free
towing? if you do, and your spouse has a card as well, you can put
200 miles on each of them for free....
... you might need to know this.....
Old May 19, 2012 | 12:47 AM
VQT's Avatar
VQT
Fulthrotl,
I only have AAA plus, didn't know about AAA premium. Will check it out
Thanks
Old May 19, 2012 | 12:50 AM
VQT's Avatar
VQT
Thanks Roasted7,
Saw that a while back
Old May 19, 2012 | 12:52 AM
Fulthrotl's Avatar
Fulthrotl
Fulthrotl,
Thanks
you can't upgrade to it unless you have a certain amount of time with
no calls.... but if you are eligible for it, grab it. once you qualify for it,
they don't take it away.
the 200 i think is a one shot thing, or very rare, but you have 100
miles whenever you need it.
two ford owners having a chat: "so, who gives the best towing package?"
sigh.
Old May 19, 2012 | 12:58 AM
VQT's Avatar
VQT
sigh.
My neighbor love Chevy and his Chevy Diesel Truck and he said so many time.
Fixed or Repair Daily
My other neighbor only have Ford but he doesn't have a diesel
First on Race Day
Old May 19, 2012 | 01:15 AM
Fulthrotl's Avatar
Fulthrotl
First on Race Day
i was driving back to work from the supply house today,
and there was a PSD 4x4, with the hood up.... in the center
island, and he driver looking with bewilderment.....
instead of offering roadside assistance, i thought maybe i
should just tell him how to find the forum......
Old May 19, 2012 | 09:31 AM
Roasted7's Avatar
Roasted7
Just FYI, I drove it like that for a year.
Old May 19, 2012 | 10:30 AM
VQT's Avatar
VQT
Did you have the EGR delete already at the time?
I don't think I want to gamble the other parts.
Old May 19, 2012 | 01:02 PM
Picard's Avatar
Picard
Has anyone ever used the datalogging feature on the SCT 3015 Tuner? Is it accurate? The readings that i'm getting would suggest otherwise. I'm showing ECT of around 192 and the EOT around 256 after 30 min of Interstate driving pulling a 2 horse trailer(unloaded). The guy that worked on my truck(ford tech that also works at his house) said it has the new software to detect a 15 deg difference but i'm not getting a cel or wrench light. Truck has egr sinister delete with A-1 Industries H11 studs, vc-9 flush and new oil cooler last August. What do you think?
Old May 19, 2012 | 01:17 PM
  #28
BLADE35's Avatar
BLADE35
Be very Careful here at 253 EOT the 6.0L will defuel
Thats pretty hot after only 30 minutes so IDK could go one way or the other
Old May 19, 2012 | 02:30 PM
  #29
Picard's Avatar
Picard
Defuel? what does that mean and what does it cause? Sounds expensive. So do you think the SCT is reading correctly? Supposed to go on a riding trip 4 hrs from the house. Don't want any issues while traveling.
Old May 19, 2012 | 02:54 PM
  #30
BLADE35's Avatar
BLADE35
The PCM will defuel to Protect the engine from a Catastropic Failure its Hard to Notice the Defuel. Folks with a EGT Gauge report temp reduction in EGT at these points of Defuel and its Not like a Total Loss of power
<TABLE style="WIDTH: 657pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=875><COLGROUP><COL style="WIDTH: 50pt; mso-width-source: userset; mso-width-alt: 2413" width=66><COL style="WIDTH: 329pt; mso-width-source: userset; mso-width-alt: 16018" width=438><COL style="WIDTH: 278pt; mso-width-source: userset; mso-width-alt: 13568" width=371><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 50pt; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17 width=66></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 329pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl66 width=438 align=left>Things that will shutdown your 6.0L (PC/ED manual):</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 278pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68 width=371></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" align=left>Fuel cut-off switch initiated (floorboard area panel - front passenger side)</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ffcc99; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 align=left>Defuel at 221 *F ECT (coolant temperature): PC/ED manual - page 1-34</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ffcc99; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 align=left>Defuel at 253 *F EOT (oil temperature): PC/ED manual - page 1-34</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl68></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ffcc99; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 align=left>Defuel at 4000 rpm's : PC/ED manual - page 1-13</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ffcc99; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 align=left>Defuel at 95 mph: PC/ED manual - page 1-15</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; mso-ignore: colspan" colSpan=2 align=left>Defuel at 28.6 psig boost (possibly also need to be at or above 75 mph also)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: #ffcc99; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl67 align=left>Defuel when the fuel level in the tank gets very low (well after the low fuel light comes on). </TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; mso-ignore: colspan" colSpan=2 align=left>The engine will not start until the PCM reads 500 psi from the ICP - will it shutdown below 500 psig?</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; mso-ignore: colspan" colSpan=2 align=left>A PCM detected fault on two of the 3 Accelerator Pedal Position (APP) 3-track potentiometer sensor signals only allows the engine to operate at idle.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; HEIGHT: 12.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=17></TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" align=left>Battery voltage below 9.5V and it won't start</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0"></TD></TR></TBODY></TABLE>
I cant say you getting good temp reading or not
But If your temps are reading right and are that High it will be a Very Big Risk to pull a Horse Trailer 4hours away loaded with Horses. I guess you could saddle them and ride the horses if you got stranded LOL
this Could be cheap or expensive IDK if it gets Pushed Catastropic engine Failure can occur you also could just have a BAD Temp sender IDK
need to verify the temps are reading right
so to do this after a 12hour cold soak Check ECT & EOT & TFT & Ambeint temp all these temps should be very close to one another after the 12 hour time frame within 1-2 degress of each other
The Main thing here with your EOT so HIGH is that if it melts Oil Filter Standpipe your Moter will be Junk at that point. Im not shure what temp this happens IIRC its in the 300* range Im not shure though
IMO your at the temp range that it needs to be addressed ASAP its not something you really want to throw on the BackBurner
