Drop my tranny
Old May 17, 2012 | 08:48 PM
RIKIL's Avatar
RIKIL
Drop my tranny
I am wondering if I would be able to drop my tranny and get it out from under the truck using a jack with a transmission adapter on it. Has anyone done this in a similar situation?
This would be for the truck I have listed in my signature below which has an E4OD and a 4" front, 3" rear Rancho lift.
Old May 17, 2012 | 09:35 PM
rangergirl94's Avatar
rangergirl94
I have done it with just a floor jack but I have a manual trans
Old May 17, 2012 | 09:46 PM
RIKIL's Avatar
RIKIL
Wouldn't the tallest part of the tranny be the bell housing? If you removed it from a 351, I would think they would be the same height.
Old May 17, 2012 | 10:57 PM
impish's Avatar
impish
My transmission jack has a vee-shaped shallow trough on which the bottom of the trans rests. This is good with manuals, as their belly usually is rounded. Autos have a flat pan. Either one, if you cvan strap it down tightly someway, to a typical "curb" jack, it can be done, carefully. Best if 2 guys do it. Get a sense for how it's balancing just as you break it away from the engine- support the engine soundly first! If balance is off, forward or backward, move it appropriately on the jack, so it won't suddenly slide or tip, forwards or backwards. impish
Old May 17, 2012 | 11:23 PM
Encho's Avatar
Encho
The Southernmost Mod
The E4OD is the heaviest trans that was fitted to these trucks, you better plan very well what you will be doing. I would try what you want to do only if the jack you have is extremelly strong and reliable, and even then I would take special care.
Old May 18, 2012 | 01:56 PM
big vann's Avatar
big vann
I did it with a c6.Removed the transfercase first.Used the trans adapter on a 2 1/2 ton trolley jack to pull it back/lower the trans and had to slide the trans off the jack to get it from under the truck(88 F250 4x4 stock height "32 in tires.)Very heavy trans when you're on the ground at the same level as the trans.A helper is a plus.Make sure you support the engine before you pull the trans off it.
Old May 18, 2012 | 03:40 PM
RIKIL's Avatar
RIKIL
OK, I looked it over and it looks like I need to remove the 4X4 shifter linkage. It's not clear to me how to do that, I see one bolt but it has a bead weld next to it so it won't move, can't really see any other places to remove it. Anyone remember how they did it?
Old May 18, 2012 | 11:46 PM
Encho's Avatar
Encho
I've heard about a shifter linkage, and you have to take out the pan to work on it.
Old May 23, 2012 | 08:31 PM
RIKIL's Avatar
RIKIL
I got the tranny back from the shop today and I have it up on the jack, ready to go in but before I put the torque converter on I thought it might slip off it's alignment as I am moving the tranny around. Is there a reliable way to secure the torque converter while I install the tranny?
Old May 23, 2012 | 11:05 PM
Phy's Avatar
Phy
Deleted. (I didn't read to the end of the thread, and was gonna tell you how to get the shifter off...)
bcuz1998
Aug 11, 2013 09:16 AM
92cruisinblue
Jul 9, 2013 11:59 PM
Fordican
Jun 17, 2011 05:19 PM
scottek
Nov 21, 2006 05:44 PM
Franklin2
Dec 18, 2001 09:32 PM
