does anyone know where i can get a programer or chip for my 96 f250 7.5l 460?
i cant find them anywhere i need more power to turn my 37's. i would rather have a programer but a chip might be ok. i hate chips but it might be my only option.
"The rearend gear ratio refers to the relationship between the ring gear and the pinion gear. By simply dividing the ring gear tooth count by the pinion gear tooth count, the ratio is determined. For example, if we divide a ring gear with 41 teeth by a pinion gear with 10 teeth we find that the gear ratio is 4.10:1 (41/10 = 4.10)."
if you chip it or program it for more power with out regearing it you will not have a decent way of geting this power to your wheells expecialy if u are runningh 37"s
Why doesn't someone just answer the question instead of saying all this other stuff lol. He was pretty specific. I'm not sure about that year so I can't answer.
I run 35's on mine with 4:56's. I have seen a lot of other gear options in some of my buddies trucks but i love the way my 4:56's perform a lot better than theres. just my .02
Hi i bought a chip for my1990 f-250 with a 351 off of e bay for $ 30.00,and it said 10 to 15 hp,but i didn't notice a difference.I have 4.10 gears to with a 5 speed and 33,s. I did notice a difference when i put shorty headers and a flowmaster on it,and a K&N air filter.Don't know if that helped but good luck.
