vacuum leak
Old May 11, 2012 | 08:10 PM
mjtpolice76's Avatar
mjtpolice76
My problem is in reg ac it works great an blows out the dash vents. When I put it in max ac it switches to a 50/50 mix between vents an defrost. What color line under the dash is leaking. Any help would be great.
Old May 11, 2012 | 09:05 PM
cory5517's Avatar
cory5517
Man there is a silvery canister under glovebox you might want to check
Old May 11, 2012 | 09:18 PM
mjtpolice76
The one with the black an white vac lines??
Old May 11, 2012 | 09:23 PM
cory5517's Avatar
cory5517
Yes, I think its called a blend door actuator.
Old May 11, 2012 | 09:33 PM
mjtpolice76
So how do u test it to see if it's bad
Old May 12, 2012 | 06:01 AM
Tugly's Avatar
Tugly
You can use a break bleeder kit to apply vacuum and test the function. [LINK]
Old May 12, 2012 | 08:54 AM
cory5517's Avatar
cory5517
I was trying to find some research on this but came up empty
High Intentions
Sep 11, 2020 06:55 PM
levimorris85
Jul 21, 2010 12:46 PM
hdman6
Sep 18, 2008 02:07 PM
harstad23
Dec 15, 2007 11:25 PM
schmittyhappens
Sep 23, 2006 10:09 PM
