Sponsored by: Real Truck
vaccum leak problem
Old Jun 23, 2010 | 04:10 PM
levimorris85's Avatar
levimorris85
vaccum leak problem
I am looking into a buddys problem for him. what it is, the ac (all positions) blows out the defroster vent. you can put it in 4x4 and then the ac blows out the vents like it should do but only for a couple of seconds, then returns to the defroster. The driver hub wont lock in all the time but does sometimes. From what i am reading on a couple of different post on here is it may be a vaccum leak or the hub pulse solinoid. The vaccum pump NEVER stops until you kill the truck. any ideas would be a great help.
2005, F-350 spduty, 4x4 ESOF, auto.
Old Jun 23, 2010 | 04:14 PM
mikesmayhem's Avatar
mikesmayhem
The default for lack of vacuum is defrost mode. There is a vacuum leak somewhere. Try to find a cracked hose or see if there is a leak in the hubs. There are other areas to look into but start with those first. Some people (including myself) just converted to WARN manual hubs and plug the vacuum lines that go to hubs.......
Old Jun 23, 2010 | 04:27 PM
levimorris85
ok, could i just plug the lines at the "T" close to the pump and work the hubs manually? And doing so would also make the ac work like it should right away?
Old Jun 23, 2010 | 04:32 PM
mikesmayhem
If you plug the line before where the leak is, the vents inside the cab will work properly.
Old Jun 23, 2010 | 04:35 PM
levimorris85
thanks a bunch. i'll let you know how it goes.
Old Jun 23, 2010 | 07:06 PM
levimorris85
ok.....we pluged the hub line next to the pulse solinoid and nothing changed, so i need some more ideas.
Old Jun 23, 2010 | 09:41 PM
Mr. Finch's Avatar
Mr. Finch
you should see a vacuum line going from the engine compartment through the firewall and into the cab, follow it back to the source, and manually apply vacuum. then follow the line listening for leaks, and as you go along, you will find spots where it splits, clamp off the splits one at a time, when you clamp a line off, and it stops leaking, then that "CIRCUIT" is where your leak is.
This is just like tracking down a short circuit.
Good luck
Old Jun 23, 2010 | 09:50 PM
levimorris85
ok, thanks i'll let you know and if anyone has some more suggestions let me know.
Old Jul 21, 2010 | 12:14 PM
levimorris85
we have traced all the vacuum lines and cant find a leak anywhere. so we have decided that even though it is a 100+ right now the defrost ac is better than the old way of rolling down the windows. If anyone can give me some help i would be most thankful.
Old Jul 21, 2010 | 12:46 PM
dchamberlain's Avatar
dchamberlain
You clearly have a vacuum leak somewhere. You need to start at the vacuum pump. Take the line off of the nipple on the pump and put your finger over it. The pump should stop. If it does, then it is OK.
Then put that line on and move to the other end of it. Do the same thing. The pump may take a little longer to stop but it should eventually.
Keep doing this, down the line, one line and connector at a time. Eventually you will find a place where the pump never stops running. At that point you have isolated your leak.
