vacuum leak
Old May 9, 2012 | 04:52 PM
cory5517's Avatar
cory5517
vacuum leak
Ok I went through the whole esof vacuum leak so I bought warn hubs and capped off all lines. Well I put my truck in four wheel drive and my ac went through my defroster...what gives? If its not one thing its another
Old May 9, 2012 | 08:04 PM
endobear's Avatar
endobear
When you have air coming out the defrost only your truck is in a default mode of some kind. Meaning you have a vacume leak somewhere
I only know this from research Ive done because my truck does the same thing. I havnt had time to look into mine yet except for checking the vacume pump.
I would suspect that you and I both could have a leak at the hubs.
Old May 9, 2012 | 08:06 PM
onelionhunter's Avatar
onelionhunter
4x4
If it only does it when you put it in 4x4, that means there is a leak between the pump, and where you capped the hub lines. trace them back to the pump and cap there.
Old May 9, 2012 | 08:15 PM
cory5517's Avatar
cory5517
Endobear I've replaced the hubs with warn manuals and capped off the lines going into the hubs.
Old May 9, 2012 | 08:26 PM
cory5517's Avatar
cory5517
I'm really wishing I had the simple on the floor four wheel drive
Old May 9, 2012 | 09:27 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Check under the dash on the passenger side. Thats where the HVAC vacuum lines come in and thats a common spot to get disconnected.
Old May 10, 2012 | 01:24 AM
Bonanza35's Avatar
Bonanza35
I had a leak under the passenger battery where acid must have driped. It eat a hole in the line. Once I fixed
it there all was well. Just thought I'd let you know where mine was. Good luck,
Chet
Old May 10, 2012 | 06:17 AM
Tugly's Avatar
Tugly
I had a leak in my ESOF module on the passenger fender (you no longer need this) and in the lines to the hubs (capped doesn't stop a split line from leaking). There are very few things that have vacuum going to them, so it's a very small list of things to check.
Old May 10, 2012 | 04:36 PM
cory5517's Avatar
cory5517
Which one puts the esof module? Anybody got any pics?
Old May 10, 2012 | 06:52 PM
Tugly's Avatar
Tugly
Bottom of the thread: [LINK]
Old May 10, 2012 | 06:56 PM
brian42's Avatar
brian42
Veteran: Navy
If the ESOF Module that Tugly refers to is the vacuum solenoid that provides the vacuum "pulse" to the hubs, then I've had the same problem. If your truck defaults to defrost mode when you into or out of 4wd for several minutes then goes back to the selected ventilation mode, this could very well be your problem or any of your vacuum line in the engine compartment. Those are the symptoms I had. I had already replaced all my vacuum line in the engine compartment and when I replaced my solenoid things worked great again (for about a year). Since you have Warn hubs you woldn't need this solenoid again. You can test this by pulling the vacuum line off of the solenoid, temporarily plugging it (could be with your finger in you have somebody to hellp you) and then turning your ESOF switch to 4hi. If your ventilation does not go to defrost, then you've found your problem and you can permanently cap that line. This will also isolate all of the vacuum line inside the engine compartment.
Old May 10, 2012 | 08:30 PM
cory5517's Avatar
cory5517
So I can remove this esof module for good since I have aftermarket hubs?
Old May 10, 2012 | 08:53 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
X2 on Trey's idea to check the vacuum connections in the cab. Remove the glove box and there they are.
When I put in my manual hubs I re-routed the vacuum line under the hood, see the pic below. The HVAC vacuum line comes into the engine bay by the hood hinge, top left in the pic. Then it went over the fan motor and center-right in the pic you will see a white cap where I disconnected it from the rest of the vacuum system. Then I ran the HVAC line straight down the fender directly to the vacuum reservoir. Pull the "T" from the reservoir (capped it in blue, foreground) and insert line from cab. A bit of spit will ease assembly. Just the right length and a handy hole to clip the line to the fender.
All that ESOF vacuum stuff can just sit there in case I want to rebuild the stock hubs someday. The HVAC gets vacuum directly.
Old May 10, 2012 | 10:05 PM
Tugly's Avatar
Tugly
Yup... gut it like a fish. Cap things off so your vents work, but anything downstream from the solenoid will just be baggage when you have manual hubs. I decided to keep my ESOF because our roads go from wet, to dry, to snow, to ice within short distances. You'll want to make sure you don't cut/disable the vacuum line to the cab.
Old May 11, 2012 | 04:24 PM
cory5517's Avatar
cory5517
I'll be able to get into it today since its not raining and hailing
