vaccum leak
Old Aug 10, 2014 | 09:15 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
vaccum leak
Ok, I know I have a vaccum leak. I have manual hubs now and those lines are capped. The AC is blowing through the deforst and the pump is running non stop. I have replaced the vac pump a couple of years ago and it worked fine then. any other places to look?
Old Aug 10, 2014 | 09:22 PM
Restlesswildman's Avatar
Restlesswildman
Is the 4wd switch tied to the vacuum system for the factory hubs?
I had a GM product that had issues with vacuum tubing from a switch to the tranny that I had to trace the lines on.
Old Sep 11, 2020 | 06:55 PM
2002Ex's Avatar
2002Ex
If your diesel is like the gasser, then it is most likely the vacuum solenoid.
Airmanpruitt
Nov 28, 2016 03:56 PM
cory5517
21
May 12, 2012 08:54 AM
stroken
Jul 22, 2010 01:57 PM
levimorris85
Jul 21, 2010 12:46 PM
Pocket
Jul 4, 2008 04:19 PM
