Diesel dies on cool mornings.
I have a 1997 F350 powerstroke with 206k. It will die 2-3 times after initial start up on a cool morning. If I plug it in it will die 0-1 times. It dies whether I let it idle or not. Once the dying period is over, it will run all day with no trouble. I just replaced a bad injector module and I had hoped that might fix the problem. I also changed the fuel filter along with all fluids as this is a new to me truck. I am calling 40-50 degree mornings cool. If it is in the 60's, no problems. Any ideas?
Yes, the glow plugs wait start light cycles off before I start.
Also, it starts right up, no problem and runs for up to three minutes before it dies.
I'd guess CPS. I've heard of them doing some REALLY screwy stuff when they start to go bad. GP's and GPR have nothing to do with it because you say it starts just fine. PCM pays no attention to coolant temp and bases all its calculations on engine oil temp (EOT), but I don't see that doing it either since it would run regardless of what it thought the EOT was. Less than $40 for a Ford CPS (don't get one from anyone other than Ford or International) makes it a (relatively) cheap experiment.
Nope, not difficult at all. It takes a 10mm socket and is located above and to the passenger side of (about the 11 o'clock position) the main crank pulley on the front of the engine. Takes 10 minutes as long as the head isn't stripped off the bolt.
Look over the wiring harness as well while you're there to make sure it doesn't look like it has been rubbing on something that could have damaged the wiring.
whiteguy589
21
02-27-2009 02:38 PM
