VERY hard to start!
I've started using it again for a week now, and it's really hard to start. It will turn for a minute or two (no smoke at first, then after 10-20 seconds the air start filling with smoke until there's a grey cloud surrounding the truck) with absolutely no sign of wanting to start whatsoever, then after 1-2 min it starts hiccuping in a way that means it's eventually going to start, and from that point the hiccups increase progressively in intensity until the engine is actually running fully at idle.
Then I have no problems with it (turn engine off, start engine again an hour later, use the truck the whole day) until the next morning.
It seems to me it's getting increasingly worse, and this morning, I actually gave up as it showed no sign of wanting to even start hiccuping...
What could be the problem? Thanks in advance for the info regarding what I should be checking!
Edit: Tanks are both half-full and the truck's parked on a near-flat surface.
I was thinking air intrusion at first, but he says he gets smoke...so it's trying to fire, but the cylinders aren't hot enough to actually light off.
Careful with that starter! They're expensive. 20 seconds cranking, 2-3 minutes cool down. Repeat.
This sounds like mine if I don't light the glow plugs after sitting overnight.
Diesel self-ignites somewhere around 400 degrees F. (Can't remember the exact number). Without glow plugs, and if the outside temperature is say 50 degrees, then you're trying to heat the cylinders up 350 degrees with just compression...
Light the plugs, cylinder heat up very quickly, then the fuel lights when you hit the key.
Don't overlook air intrusion though, it's a very common problem with the IDI's. Especially around the return lines, the rubber hoses running between each injector. Dont disturb those, or else they'll start to leak and then you'll really have a tough time starting...
To test the glow plugs use the following procedure:
1; Unplug the glow plug you are going to test,
2; Take a 12V test light and connect one end to the batter and the other end to the glow plug,
3; If it lights up, the glow plug is likely healthy, if not its dead.
If 2 or more glow plugs die in th system, the controller will no longer cycle. Its a feature of all 87 and up IDIs that use the electronic closed loop controller. Don't use anything other than beru glow plugs.
My current starter is brand new... I guess I'm the one responsible for killing the last one this winter as I had no glow plugs and was often away from home (couldn't plug the block heater so I had to crank it forever to start it). I'll make sure I go easier on this one, thanks for the advice!
The general rule for not killing a starter is maximum 20 seconds cranking and minimum 2 minutes cool down.
These engines have a lot of cubes and even more compression so they are very hard on starters if you have to crank them for any length of time.
A big hair drier or heat gun pointed down the intake can also do the trick in some cases.
