Hard Start
Old Apr 7, 2011 | 07:26 AM
Reddogdiesel's Avatar
Reddogdiesel
Hard Start
I have a 94 F350 and it ran great until I changed the fuel filter. Ever since it got changed when its cold and I start it it will run for a few seconds then die. Then I have to crank on it for a while until it starts again. It will run rough for a few seconds, then clean up and run fine. Any thoughts?
Old Apr 7, 2011 | 07:28 AM
Reddogdiesel
Also from time to time when its cold it will make a clicking noise when I turn the key on and the voltage gauge with jump up and down for a minute or two. Could that have something to do with the start issue?
Old Apr 7, 2011 | 07:41 AM
Reddogdiesel
Ok, started truck again this AM and no clicking and hard to start. Just trying to put as much info as I have...
Old Apr 7, 2011 | 07:48 AM
Phy's Avatar
Phy
The hard start sounds like air getting in to the filter. The truck starts, the air gets pushed into the injection pump & it stalls. You crank a while & the air gets purged and it starts again...
The clicking & voltmeter activity is the glow plug controller cycling. It The wait to start light should go on for about 10 seconds while the glow plugs heat up, then the WTS light goes off, and the glow plugs cycle for a few seconds to help keep it running...
Old Apr 7, 2011 | 08:16 AM
Reddogdiesel
Wait to start light does stay on for about 10 seconds. Is it normal for it to make the clicking noise sometimes and not others? Any way to get air out? I have tried bleeding the fuel filter but that didnt help.
Old Apr 7, 2011 | 08:28 AM
Phy's Avatar
Phy
The glow plug controller works differently depending on temp. The sticky threads at the top of the forum will tell you all about the system.
Since the hard starting issue started after changing the filter, it's a pretty good assumption that the new filter isn't sealing, or one of the lines attached to the filter head were disturbed...
Old Apr 7, 2011 | 08:31 AM
84-6.9L's Avatar
84-6.9L
Check and make sure thebleeder valve is sealed good. Is it possible you bumped your return lines when changing the filter? If so thats where your air is getting in. Do any of the caps look wet? If so get an injector install kit and set the crush washers aside and replace the o-rings caps and lines and enjoy fast studder free starts!
Old Apr 7, 2011 | 11:53 AM
snaponprofile's Avatar
snaponprofile
Yes, thats normal. When it is cold outside your voltage gauge will fluctuate right after start up while the glow plugs cycle. This is called a afterglow and you should hear some clicking. If it's warm outside it won't afterglow and it won't click after start up - it will just start up.
It sounds like a air intrusion problem to me. Leave your fuel filter over night and unscrew it the next morning. If it is not completely full, you have air intrusion problems.
Hyperryd
Oct 8, 2013 09:00 PM
Deadeye1445
Nov 21, 2012 01:58 PM
chandler95bronco
1978 - 1996 Big Bronco
Jan 10, 2011 01:19 AM
DanCampbell
Dec 20, 2010 07:12 AM
kereed57
Oct 9, 2010 09:27 AM
