Minnesota Chapter Join Chapter, Leader: fordpower88
Spring is almost here March BS thread!
Old Mar 5, 2012 | 03:37 PM
  #436
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by dlibson
Ok guys, on the t-stat debate, it is electronically impossible for it to improve mileage. The computer naturally has two settings for fuel use. Open and closed loop. When it gets to a certain temp, it will use less fuel then when cold. It won't continue to use less just cause its slightly warmer. Not to mention 8* in the coolant won't equal the same in the combustion chamber.
If it was this simple, itd be that way outta the box. What warmer temps can do is give better heat.w Otherwise heat = wear. Warmer means oil breaks down quicker, engine stress more, and tranny as well.
Just to beat this down closer to china, this post has dieselsites reasoning
https://www.ford-trucks.com/forums/6...nightmare.html
Old Mar 5, 2012 | 03:38 PM
  #437
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by DieselCamper01
Once you go dark chocolate you never go back...
You got that right
Old Mar 5, 2012 | 03:39 PM
  #438
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by Devious Delight
me too... I couldn't remember what she liked, so I sent her a lb of desert truffles. Figured I couldn't go wrong.
Smart move and excellent cause
Old Mar 5, 2012 | 03:55 PM
  #439
fordpower88's Avatar
fordpower88
Sounds to me like the big concern is the stem length on the t-stat and as long as your are running his or OEM you should be good to go. Other then that it is pretty much like the ongoing which tuner is better argument. Pick the one you like and go with it
Old Mar 5, 2012 | 03:58 PM
  #440
DieselCamper01's Avatar
DieselCamper01
That, my friend, is called excellent marketing.
Old Mar 5, 2012 | 04:02 PM
  #441
fordpower88
You know I was gonna mention that but I bit my tongue on that one! LOL
BTW I see according to the new tag line I learned something today!
Old Mar 5, 2012 | 04:09 PM
  #442
dlibson's Avatar
dlibson
Michael, the plastic pile has been okay to me so far. I had to start with it junk, so the upper end is all new. No leaks from that yet. It's what I expected for a '93 pos though.
Old Mar 5, 2012 | 04:11 PM
  #443
dlibson's Avatar
dlibson
I totally agree with the t-start thing being a pick your pony and shut it thing too. I don't care what you do, don't push it on me though...
Old Mar 5, 2012 | 04:17 PM
  #444
wildstang's Avatar
wildstang
VT Chapter Ldr
Its all good in theory, in reality too minute to measure. It improved my cab heat compared to what it was
Old Mar 5, 2012 | 04:19 PM
  #445
wildstang's Avatar
wildstang
VT Chapter Ldr
Cold today, not used to it not going above freezing. LOL
Old Mar 5, 2012 | 04:26 PM
  #446
DieselCamper01
That is exactly what counts.
Old Mar 5, 2012 | 04:30 PM
  #447
HP junkie's Avatar
HP junkie
whoa!
this seems good...
2004 F-350 Diesel Lariat Crew
I called on that the same day I looked at mine. He has reciepts but packed away. I believe it was a company rig.
Old Mar 5, 2012 | 04:34 PM
  #448
wildstang's Avatar
wildstang
VT Chapter Ldr
Looks like it sits low for an f350
Old Mar 5, 2012 | 04:37 PM
  #449
wildstang's Avatar
wildstang
VT Chapter Ldr
He must have close to half that price in the parts and labo
Old Mar 5, 2012 | 04:50 PM
  #450
HP junkie's Avatar
HP junkie
I see I started a debate with T-stat question. What else can I do to up the post count.................I heard you can increase mileage by adding two stroke oil to your fuel.
There that should do it. lol
