Minnesota Chapter Join Chapter, Leader: fordpower88
Spring is almost here March BS thread!
Old Mar 5, 2012 | 09:12 AM
  #391
fordpower88's Avatar
fordpower88
Originally Posted by DieselCamper01
Good morning Troy.
I had heat before I was half way to work. Just sayin'...
About 15* here.
Good morning Jay! Nice to have that heat isn't it Jay!
Originally Posted by HP junkie
Well my brother saw the temps and said my T-stat is bad. He said temps should run in the 190ish range.
So he must think it is stuck open? How long does it take to get to that temp? I would think if it gets there relatively quickly you are ok like Dave said.
Seems to me if the t-stat was stuck open it would never get to even 184 especially in the winter.
Originally Posted by Devious Delight
umm dude needs a clue...
and that exhaust...
91 f250 7.3 idi turbo diesel 5spd only 82000 m
Wow needs a new exhaust tip bad!! LOL
whoa!
this seems good...
2004 F-350 Diesel Lariat Crew
I think Cory called on that one when he was looking.
Old Mar 5, 2012 | 09:55 AM
  #392
Excursion4X4's Avatar
Excursion4X4
Good morning MN!
Old Mar 5, 2012 | 09:57 AM
  #393
DieselCamper01's Avatar
DieselCamper01
Good morning Dale. Hows the Ex?
Old Mar 5, 2012 | 10:01 AM
  #394
Devious Delight's Avatar
Devious Delight
Good Morning Dale.
Old Mar 5, 2012 | 10:07 AM
  #395
wildstang's Avatar
wildstang
VT Chapter Ldr
Can you get hotter thermostat for 6.oh no? I put a 203* one in my 96 7.3 and now I have nice heat in the winter. I might do that to the excursion because according to the gauge it tuns cool. If it runs warmer it should help with efficiency, burn the diesel better.
Old Mar 5, 2012 | 10:09 AM
  #396
wildstang's Avatar
wildstang
VT Chapter Ldr
But I actually am not sure what the actual coolant temp is. Maybe the 203 thermostat brings the actual coolant to 184 range.
Old Mar 5, 2012 | 10:11 AM
  #397
Excursion4X4
Morning, Jay and Dustin. Still liking the Ex Jay. Quiter and More power...and better MPG's.
Old Mar 5, 2012 | 10:14 AM
  #398
DieselCamper01
Those are good things. Except the quieter part.
Old Mar 5, 2012 | 10:16 AM
  #399
fordpower88
Originally Posted by Excursion4X4
Good morning MN!
Good morning Dale!
I am not sure if they can get a warmer one or not for the 6.0 but the stock one should work just fine if you ask me. I have the stock one in both my psd's. I have never thought that it doesn't get warm enough. My '94 will roast you out on the low fan setting and my '01 is about the same and that is with no winter fronts on the trucks of any sort. I know there is a lot of discussion about the 203 thermostat as far as better fuel mileage because it helps burn better but I am not a believer myself. What little you will gain if any will be so little I don't see it being worth it in IMHO.
Old Mar 5, 2012 | 10:17 AM
  #400
fordpower88
Glad your liking it Dale! What are you getting for mileage?
Old Mar 5, 2012 | 10:19 AM
  #401
Devious Delight
If swapping the thermostat gets you 1mpg, wouldn't that be worth it?
What's a thermostat run? $20 and 1 hour?
So what would it take to make up $20, 3 fillups?
Old Mar 5, 2012 | 10:23 AM
  #402
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by fordpower88
Good morning Dale!
My 96 was a cold pig also until I put the warmer t stat in. Since then it puts out good heat and the needle rides in the center of the temp range. The excursion needle rides in the low end like my truck used to.
Old Mar 5, 2012 | 10:26 AM
  #403
wildstang's Avatar
wildstang
VT Chapter Ldr
Times 2.5 on the price. I had to go through I think diesel site to get it because I believe that hotter one was not made by international. I did it more for cab heat in the winter. So it was worth it.
Old Mar 5, 2012 | 10:28 AM
  #404
fordpower88
Someone is gonna have to prove to me that you will gain 1 mpg. I don't think it is near that much.
You know it is funny because some guys like you had trouble with heat and it fixed it and I never have so I think it is just a matter of how lucky a guy is on how there truck reacts to the cold. LOL Main thing is it worked for you. Did you keep track of fuel mileage before and after on a consistent basis?
Old Mar 5, 2012 | 10:33 AM
  #405
Ford79's Avatar
Ford79
Good morning again.
Back from the gym.
Working on getting the rear speakers installed in my car. It never had them to start with, so I picked up the housings at the junk yard the other day and had some brand new speaker laying around to put in them. The speakers that were in the housings were SHOT.
and that exhaust...
Does one REALLY need an exhaust tip that a basketball fits in???
Get a couple of those for the Subaru........
Good morning MN!
Good morning Dale.
Well, stock is 195 degree I believe, can't really see that extra 8 degrees making all that much difference IMO.
Good morning Dale!
I agree Troy. My truck, once fully warmed up, will roast you out of the cab. Even on the cold days.
I really can't see 8 degrees in water temp making all that big of a difference.
