Dear Diary . . .
Old Nov 16, 2014 | 03:09 PM
  #91
Samsn4's Avatar
Samsn4
Off Road, Sand Rail, Dune Buggy, UTV, Weld-on Mounts, Tabs & Accessories
Old Nov 17, 2014 | 12:32 PM
  #92
arctic y block's Avatar
arctic y block
Subscribing. Glad to see ya back at her Bud.
Old Nov 17, 2014 | 02:41 PM
  #93
ALBUQ F-1's Avatar
ALBUQ F-1
That cab is not a 56.
Old Feb 18, 2015 | 11:10 PM
  #94
Samsn4's Avatar
Samsn4
Winter Sucks when you don't have a garage.
Old Mar 3, 2015 | 08:26 PM
  #95
Outlaw56's Avatar
Outlaw56
Winter sucks even when you do have a garage, lol.
Old May 23, 2015 | 06:48 PM
  #96
Samsn4's Avatar
Samsn4
PARTS ARE IN !!!
I figured my current front cab mounts are not going to last to long so i went ahead and swapped them out now.
New bushing and spacer mock up
Old May 30, 2015 | 05:51 PM
  #97
Samsn4's Avatar
Samsn4
It's brake time. Waiting on parts to arrive i figured i would pull the brakes and see what i have going on. They are dirty but it looks like i can save it.
Old Jul 24, 2015 | 09:45 PM
  #98
Samsn4's Avatar
Samsn4
Old Jul 24, 2015 | 10:12 PM
  #99
fordman75's Avatar
fordman75
It's looking good! Nice work.
Old Jul 25, 2015 | 07:33 AM
  #100
Samsn4's Avatar
Samsn4
Thanks
I bought a sandblasting attachment for a pressure washer from Northern Tool
General Pump High-Pressure Abrasive Blasting Kit — 3,500 PSI, 8.0 GPM | Pressure Washer Sandblast Kits Nozzles| Northern Tool + Equipment
backed it with a 3000psi washer and blasted the crap out of it, I didn't even have to cut the hose shorter. The one key thing that i figured is to keep the sand feed tube that attaches to the nozzle pointing up so that water doesn't run down it.
Old Nov 3, 2015 | 07:27 PM
  #101
Samsn4's Avatar
Samsn4
Old Nov 3, 2015 | 07:45 PM
  #102
fordman75's Avatar
fordman75
Starting to look like a truck again!
Old Nov 5, 2015 | 09:41 AM
  #103
ford_pickup's Avatar
ford_pickup
Awesome job thus far, how did you like that blaster, it looks awesome
Old Nov 6, 2015 | 02:53 PM
  #104
Samsn4's Avatar
Samsn4
The power washer sandblaster works surprisingly well, I didn't have to shorten the siphon hose. It works best if you have a buddy to shake the bucket or bag of sand every now then and you can just let her eat. Like I mentioned above the only downside was the siphon input at the nozzle you just have to make sure to keep that pointing up so that when you let off the trigger of the power washer the water does not back wash down the siphon tube and clump it up.
Old Nov 9, 2015 | 10:45 AM
  #105
Samsn4's Avatar
Samsn4
This past weekends progress, got the rear cab mounts bolted on, probably going to wield them also.
