Dear Diary . . .
Old Mar 9, 2012 | 02:59 PM
Samsn4's Avatar
Samsn4
So i spent all last night researching info for my motor, the 300/6. There is so much stuff out there it's almost overwhelming.
Here are a few:
  • 240 head between 72-74
  • EFI maniford
  • Offy intake
  • Comp cam
  • have the block Magnafluxed
  • Balance the bottom end
  • install ARP screw in rocker studs
  • 'Deck' the block to improve compression
  • use flat top pistons
  • Steel, not fibre, Timing gears
  • Studs vs. Bolts for the head
  • ARP head stud kit
  • use a Felpro HP head gasket
  • under intake carb heating
  • Offy C intake
  • Autolite 2150, Rochester 2G or 2GC, Webber
  • Difference in Heads - 300 # xxTE , 240 # xxAE
  • use Mr. Gasket #260
Just to name a few.
The plan so far is to strip the EFI off, leave the manifolds, and bolt on a 4bbl intake with a Webber 2bbl.
Old Mar 9, 2012 | 03:55 PM
fordman75's Avatar
fordman75
Here are a few:
  • EFI maniford
  • Offy intake
  • Comp cam
  • ARP head stud kit
  • Offy C intake
Just to name a few.
I'd skip the Weber or Rochester carbs. If you are going 2V go with either an Autolite 2100 or Motorcraft 2150. Don't go smaller then the 1.08 ( number cast in the side of the fuel bowl ) . I actually prefer the 1.21 or 1.33 carbs on the 300.
Old Mar 11, 2012 | 03:03 PM
Samsn4's Avatar
Samsn4
And here's the motor
Old Mar 11, 2012 | 09:25 PM
Brian's 48's Avatar
Brian's 48
That's going to look a whole lot better once you get all the EFI and pollution stuff off. Are you using the C6?
Brian
Old Mar 12, 2012 | 09:12 PM
Samsn4's Avatar
Samsn4
just stripped the efi off, it looks more like an actual motor. yes I am using the c6.
Old Mar 12, 2012 | 09:34 PM
Rojak's Avatar
Rojak
Welcome. Good to see another FTE from IL. Looking forward to watching your progress.
Old Mar 17, 2012 | 09:29 PM
Samsn4's Avatar
Samsn4
So, can i use and what are the benefits of using an EFI head with a carb ?
Old Mar 25, 2012 | 03:44 PM
Samsn4's Avatar
Samsn4
And it's out, the motor that is. It gave a good fight, but I prevailed. It's amazing how many fixes and patches where done.
Old Mar 26, 2012 | 08:30 AM
COMPLIT1107's Avatar
COMPLIT1107
Fixes and patches? Yeah it's amazing what some POs did , while others did it right! Good luck on the truck!!
Old Apr 3, 2012 | 08:48 PM
Samsn4's Avatar
Samsn4
well here a few more pics. i am in a bit of a lull, trying to sell parts the more cash. EFI system from a 300 i6 and a 3.8L V6 with a C6 trans
Old Apr 3, 2012 | 09:05 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
OK, you may need some more lights on the back... just kidding. Nice truck!
Old May 9, 2012 | 10:05 PM
Samsn4's Avatar
Samsn4
well it's been awhile, but i have the truck in parts and starting to plan for my first step towards Truckdom. I got a corner in the basement cleared out to rebuild the motor, so i believe i'll start there, or should i get the front disc kit ? . . . . . I'm thinking motor, that will be a good accomplishment towards it.
Old Jun 8, 2012 | 11:30 PM
  #28
Samsn4's Avatar
Samsn4
Frame Coating time with POR-15
Wow, it's been awhile. So i got the rebuild kit in, engine build has been cut to get it running, and polish the head.
Getting ready to send the frame out to get coated with POR-15, is there anything i need to pass along to the paint shop, they have used it before, but it sounded like only two or three times. I trust the shop so, is there anything i need to bring up that would be special to using this product ? does it build up thick through the bolt holes, etc
And when i go to assemble do i need to give special treatment to the bolt holes so as not to remove any coating, or is it that hard ?
Old Jun 16, 2012 | 12:53 AM
  #29
Samsn4's Avatar
Samsn4
So how far do strip the frame down to paint it (POR 15) ? do i remove the leaf spring brackets, and running board brackets ? then what do i use to attach them back on, grade 8 bolt good enough ?
Old Aug 21, 2012 | 06:22 PM
  #30
Samsn4's Avatar
Samsn4
So it's been a while and i have been dragging my feet. Now it's time to kick my a@@ into gear and start working. The plan to hopefully get it rolling by, no later than, November. That give enough time to run the bugs out before heading out for the LA road trip.
So right now i"m doing a build list with parts needed and price ranges, that will get posted soon. so as my brother would tell me "Don't be lazy, and get it done!"
