Headlights and HID's
Old Feb 6, 2012 | 07:47 PM
  #91
High Intentions's Avatar
High Intentions
Mod Specialist ;)
4300 and 5000 are very close in color. as for 55w I have to double check what mine are.
Old Feb 6, 2012 | 07:52 PM
  #92
archtaan's Avatar
archtaan
Mine are 35w and I am 100% pleased with them.
Old Feb 6, 2012 | 08:02 PM
  #93
High Intentions
Mod Specialist ;)
Mine are 35w as well
Old Feb 6, 2012 | 08:30 PM
  #94
Snowseeker's Avatar
Snowseeker
Think I'm going with the 35W 4300K digitals. Get fogs too?
Old Feb 6, 2012 | 08:35 PM
  #95
archtaan's Avatar
archtaan
Yes, get the fogs too. It looks dumb with nice white HID's and yellow fogs. I will be upgrading my fogs as well!
Old Feb 6, 2012 | 08:42 PM
  #96
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Originally Posted by robert_l_ross
Guys correct me if I'm wrong, but there are two ways to get both high and low beams through one bulb.
You can a) have the bulb move a tiny bit to replicate both filaments in your stock incandescent bulb. If you look at it, the two filaments are a few millimeters apart...the HID bulb can move from say straight out to a slight downward angle to mimic that. I personally don't know how comfortable I am with that type of setup - I don't know how the mechanism holds up to vibration over thousands of miles and months of driving.
Or you can b) have two distinct arc areas in the bulb...one sits where the low beam filament would, the other sits near the high beam filament location.
In my mind, less moving parts will always be better as far as reliability...so two arcs IN THEORY should last longer.
The really cheap kits you see will not have either...it will be one arc that usually ties to the low beam and you have to give up your high beam, or get a housing that lets you run HID in a low beam projector and run an incandescent bulb in a high beam reflector.
Personally, THOSE are the ones I typically see ricers run that blind you...the projector beam has no cutoff built in, so the light just goes everywhere.
Your original question...bi xenon is two separate arcs. Xenon is either 1 arc and a housing that moves the bulb or just one arc.
Am I right guys, or am I using the wrong terminology?
i have been running ebay bixenon (where the bulb moves in/out) since 2007. i have the first kit i ever bought from them its been installed in both my dads explorers since '07 and still works perfectly. they hold up very well to vibration/harsh weather as we have alot of both in alaska.
heres a vid that shows mine. just pay attention to the first 15-25 sec you can see the high/low beams. try to disregard my 4 hella's with 100w yellow bulbs that are tied into the highbeam's. you can see the highbeam function works very well. this is a $79 kit and its 55W i got in november of 2010 when i bought this excursion.
random drive / Christmas lights 12/7/11 - YouTube
heres mine, 8000k 55w. i am using white LEDs in place of the fogs and they match almost perfect. something to keep in mind..any 55w will be whiter then its 35w counterpart. my 8000k 55w's are very close to a 35w 6000k.
heres the kits i have, installed in my f-250, bronco, excursion, expedition and my dads explorer also my grandpas f-150
http://www.ebay.com/itm/50W-55W-VVME...ht_6546wt_1270
Old Feb 6, 2012 | 08:47 PM
  #97
Snowseeker's Avatar
Snowseeker
Fogs are H3 bulbs correct?
Old Feb 6, 2012 | 08:49 PM
  #98
archtaan's Avatar
archtaan
Not 100% sure. I thought they were H10 9145's. Let me Google.
Old Feb 6, 2012 | 08:50 PM
  #99
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i used 9145's in my stock fogs.
Old Feb 6, 2012 | 08:52 PM
  #100
High Intentions
Mod Specialist ;)
Awesome Alaskan. what color are they?
Old Feb 6, 2012 | 09:11 PM
  #101
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
back when i had stock foglights, i used 12000K bulbs. but this summer i ditched the factory fogs and now have trailer LED reverse lights(in pic above) as they work better for daytime running lights which is how i have them wired.
Old Feb 6, 2012 | 09:13 PM
  #102
High Intentions
Mod Specialist ;)
I meant your headlights.
Old Feb 6, 2012 | 09:14 PM
  #103
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
lol oh my baddddd
i think i put it in there...but i did kinda ramble.
i have 8000K 55w in the headlights
Old Feb 6, 2012 | 09:15 PM
  #104
High Intentions
Mod Specialist ;)
Sorry Just saw 8000... oops
Old Feb 6, 2012 | 09:19 PM
  #105
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
it was a bit hidden...your forgiven this time haha
