Fuel Filter Analysis (Epic's request)
I didn't add this to kper's thread becuase I had a different outcome (for lack of a better word).
This fuel filter change is at 40,000 kM (25,000 miles). The filters were changed previously at 20,000 kM (12,000 miles).
The first thing I noticed was the DFCM bowl was extremely had to get off this time (was not last time). It took substantial force to turn it for the first 3 or so turns. To the point where I thought I was going to break it. Something was causing it to bind......(more on that later).
First look at the DFCM filter and all looks good. So far so good.
However, when I looked in the DFCM bowl I saw something. If I was not looking for something maybe I would have wiped it out and not thought a thing about it. But on closer inspection the stuff is in fact very fine metal filings!! No question about it. It's not dirt or anything else. It is metal filings 100% no ifs and or buts. It is like about what you would get if you were working with a very fine file on steel.
A closer look at the DFCM filter and you can see it in there too....
It is definately metal, a magnet will pull it right off the filter or out of the bowl......
This stuff is too big to get by the DFCM filter and into the secondary filter. There is nothing visible in the secondary engine mounted filter.
The DFCM bowl was binding because of the metalic debris in the threads (the threads are below the o ring and in the fuel basically)......
Like someone here said, the fuel pickup is above the bottom of the tank. This stuff would be on the bottom of the tank but obviously the fuel moving around in there is enough to mix it up and suck it up.
If I was not looking for something I likely (maybe) would have just called it crud and wiped it off and never gave it a second thought.
I am now (thanks a lot Epic
) interested to see if anyone else sees this.You guys have fun with this one...I am going back to "head in sand" as it is WAY WAY WAY more fun than this. And I am being serious (for a change) for me too much information is not a good thing. I love my truck. This is a once in a lifetime vehicle for me. I have ALWAYS bought what I could afford, this is the first time ever I bought what I wanted. I will continue to enjoy it
After all, if there really is a problem someone will step up to the plate and fix it right?? (OH YA, just remembered, life aint always fair
)Good luck to you all.
Analysis of its composition will lead you to exactly what part they came off from.
Do we know if Bosch used a coating on the CP 4.x HPFP?
The use of a coating, and its subsequent failure after a period of time, would explain why it took so long for failures to start cropping up.
Since the CP 4.x is suppose to be cheaper to build, it follows that someone found a way.... what changed between CP 3.x and CP 4.x beside a higher maximum pressure?
My filter had more debris but my HPFP had failed catastrophically. The debris was also a mix of aluminum and steel. The camshaft is steel. Mine was scored and one lobe had eroded quite a bit. The rollers and their seats are also steel. They were also scored and showed obvious loss of metal...but no evidence of water infiltration.
Regards
If Ford thinks the pump is perfect, why are there even metal bits returning to the DFCM?
I need to change the oil this weekend @ 5,800+ miles so I may as well change the fuel filters, too.
Mine will be needed in 3,000 miles anyways.
For now I am going to drive it and see what happens over the next few months.......
IF there was an upgraded or better (aftermarket) pump available I would definately consider putting it in NOW. But I don't thnik I am going to spend the money and put the same pump in at this point
My truck is tuned and pretty much always has been. I like to get on the throttle. But 99% of the time I drive around in the "mild" mode which has the claibrations not much over stock. I only have 25,000 miles on the truck.
Not that I think it will matter at this point but I am going to give up my beloved stanadyne and switch to opti lube XPD
I am very
Kper, don't do what I did. I changed my oil last night too. But I was so flustered after finiding the metal I started the damn truck with no oil in it ARG, I really don't need this
Thanks
Thanks for the great info. I wonder if the steel particles came from the outside in or inside out to the tank. Maybe a filter on the return tube to the tank is worth trying?
-Gavin
Thanks
At the pressures they are pushing.. don't expect an "aftermarket" to come out anytime soon.
It is beyond the abilities of 99.999999% of the shops in the world.... including some very well equipped, high tech manufacturing facilities in China, India, etc. that would love to put out a clone pump and undercut Bosch.
Thanks
Not an engineer so pretty much on the edge here.
Sometimes the simplistic solutions are the best.
